Renault Traffic Gearbox Problem
Started by Rods2, 01 June 2012, 01:01:01
Rods2
A friend has a 2002 Renault Traffic 1.9/2.0? SL27DCI and first gear has gone. Apparently this is a common problem
He has been quoted £700 for a reconditioned gearbox with 12 months warranty, plus £250 for fitting.
Has anybody got any suggestions for fixing it more cheaply?
Martian
Breakers yard and change it yourself.
Sam Burton
Renault trafic/Vauxhall Vivaro/Nissan Primestar betweeen 2001 - 2011 Have a problem with there Gearbox to much weight and too much torque going into a light commercial gearbox terrible design, but as far as im aware there is no modification its only in the last two years Renault have held there hands up and recalled/replaced the gearbox on there latest model,
You can either replace and throw away, or like most Pre-facelift Trafic owners get a scrappy one and when you can afford it get the one thats in it at present rebuilt for when it goes again  :-\
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
Try and find a good one from a scrappy, and find a cheaper place to fit it. You get people who say there's nothing wrong with the gearboxes on them, they're talking utter rubbish they have a problem, a friend of mine has had three gearboxes in his 54 place tragic and he's covered 138,000 miles. It's a shame because they're good vans, they're comfy, they go well, they look good and other than the gearboxes and a few other bits they're generally good vans. I had one and I liked it a lot.
Sam Burton
I agree there a smart looking van and when there running they driver really well specially the higher engine range ones you can half have some fun ::) :D :y just a shame about the chocolate gearboxes
That what happens when you fit a french car gearbox to a heavy weight vehicle.
Quote from: Marks DTM Calib on 01 June 2012, 10:16:54
Fixed...
Zippy2012
The main issue on the traggig gearbox is its oil delivery to the gear shafts! 1st 6th reverse are on the same shaft at the far end & due to its design its the last for lubrication i had a new 55 plate sl27 had 3 NEW gearboxes in it!! 15000mles 38000mls & 62000mls & they were all caused by not enough oil lubing the gears & the last gearbox at 62000 went all the way up to 169000miles with no probs i used a lucas or comma gear oil stabiliser that turns your gear oil into like a honey coating everything inside but i had gear oil changed on every oil change at 12000mles & never had a prob since, ive got a spair gearbox here for a laguna 1.9dci i believe its the same gearbox... i have to as a mate from renaut to make sure tho  :-\
henryd
Odd viewing this thread as just been looking at a 57 plate traffic which has lost 2 4 and 6th gears ::)
other rides
Zippy2012
57 plate prob with a 2.0dci uses an even crapper gearbox with same issues thats why they recalled the new ones but obviously this one got missed then...
henryd
Quote from: Zippy2012 on 01 June 2012, 11:55:06
!st and reverse are quite easy to get,3rd and 5th less so and nothing going the other way 2 4 6
other rides
