Pages: [1] 2 3  All   Go Down
Author Topic: elite wont run on gas. HELP  (Read 6257 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« on: 02 June 2012, 13:18:15 »
right, here we go again....ran the 3l out of gas last week.
went & filled her up today, on switchover it cuts straight out, can hear the injectors ticking but cuts out.
checked fuses & all seems ok. seems as though it has no gas but its got a full tank.
Any help please on this or it will be going, ive just about had it with this car.  >:(
Re: elite wont run on gas. HELP
« Reply #1 on: 02 June 2012, 13:20:41 »
Is the evaporator/vaporiser cold?
The Red Baron
« Reply #2 on: 02 June 2012, 13:21:49 »
nope, nice & warm. not frozen up. :y
« Reply #3 on: 02 June 2012, 13:22:55 »
What system is it, can you do any form of diagnostic code reading?
The Red Baron
« Reply #4 on: 02 June 2012, 13:24:07 »
its romano, i dont have any diag equiptment tbh.
martin42
« Reply #5 on: 02 June 2012, 13:34:35 »
is there a way to bleed the system,could be an airlock
« Reply #6 on: 02 June 2012, 13:38:11 »
Check that both the solenoids are actually firing when the power is sent to release the gas. Sounds like either a trigger wiring fault or knackered solenoid to me, but that's just a guess from the symptoms ;)
I'm assuming you've tried several times and it's not just got a drop of vapour in the lines from running out (although it shouldn't) ???
The Red Baron
« Reply #7 on: 02 June 2012, 13:42:08 »
when i switch over....give it a blip & you can hear the ticking, seems like no gas. ive tried it several times.
was wondering about a blockage/air lock but as you say it shouldnt happen.
The Red Baron
« Reply #8 on: 02 June 2012, 14:15:42 »
paul, could the filter be blocked?.
« Reply #9 on: 02 June 2012, 14:41:18 »
Given it happened when it did, I'm thinking airlock as well. Anything else is too coincidental.
The Red Baron
« Reply #10 on: 02 June 2012, 14:48:02 »
ive checked the filter & its clear. how can i get rid of an air lock?.  :)
martin42
« Reply #11 on: 02 June 2012, 14:50:34 »
need to release some gas as close to engine as possible,at a union if there is 1 fitted,
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #12 on: 02 June 2012, 14:58:08 »
The filter should of been ok as it was a new one fitted just before you bought her Jon  :-X
AKA - Mr Bracket
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #13 on: 02 June 2012, 15:28:25 »
Maybe try to keep force starting it on gas?
The Red Baron
« Reply #14 on: 02 June 2012, 16:22:05 »
tried it with the pipe off the vapourisor(outlet) when it switchs over, nowt comes out at all.  ???
Pages: [1] 2 3  All   Go Up
