CD safe ?
Started by omega3000, 04 June 2012, 15:20:58
About time i tried the cd player today i thought , never tried it so loaded up the cd's in the boot and off we went for a drive to the shops ..turn on cd player and came up CD safe  ::) whats all that about , the radio works fine  :-\
Quote from: eatmydust on 04 June 2012, 15:20:58
it's waiting for its own code  :y :y
Quote from: Andy B on 04 June 2012, 15:50:23
Is that the same code for the one i used for the radio ? Or is it knackered  :-\
Quoteit's waiting for its own code
Do you mean i should leave it turned on and wait till it finds its code andy  ???
Is this the procedure  :-[
Quoteignition on
turn radio off
switch on radio - keep CD button pressedtill you hear a confirmation beep
display should show ''CD-CODE'' for 3 secs
then CDC code and the number of remaining attempts eg ''----<10>''
enter CD code via key pad
confirm OK by pressing large multi-functional control button
Quote from: eatmydust on 04 June 2012, 16:53:43
The CD changer has its own security code ie another code that different from the radio.  ;) ;)
Quote from: eatmydust on 04 June 2012, 16:53:43.....
Quoteignition on
turn radio off
Sounds about right  :y :y
 :( arrh that might be a problem , can only remember seeing one code but will try and find it  :y
Just read that the code is the same for both radio and cd , only one written down  ???
On the Omegas I've had radio code is different to CD code - both codes on the car pass :y
Quote from: dbug on 04 June 2012, 18:08:05
A bit of investigation work , seems someone thought it was a good idea to scrawl through the number to hide the cd code  >:( just managed to make out the code . All up and running now , i take it if i had no code i would have to take it vx  :y
Dave DND
Quotei take it if i had no code i would have to take it vx  :y
Nope, you would need to contact me instead !!
Radio & Decoding Technician
www.dndservices.co.uk
Quote from: Dave DND on 04 June 2012, 19:04:15
;D :y
