Work on The Manual Conversion has Begun! (Pics)
Started by JamesV6CDX, 04 June 2012, 21:38:09
All done, aside of reverse light wiring: car is running
Well where do I start..
WOW
It's an animal. Easily in the licence looser category! Really is an angry beast, drives great.
On the downside
the gearbox has got quite a prominent whine. Especially in first three gears...
Can someone confirm what oil type and amount goes in a manual box?
Thought I had a load in the shed but I don't...
Will try an oil change in the box, but I suspect it's knackered, and I'll have to change it next week :(
cheers :y
blackviper90210
Excellent news James, well done mate.... Good effort :y
AKA - Mr Bracket
blackviper90210
Right, now you've done that I've got a list of jobs ;D ;D ;D ;D ;D ;D ;D ;D
Grabs hat and runs off into the distance ::)
AKA - Mr Bracket
Quote from: JamesV6CDX on 17 June 2012, 20:15:44
WOW
On the downside
cheers :y
Good fully synth or VX own, part #93165290 app. 1.6 ltrs, so if using VX, 2 bottles
PAULCDX
jonnycool
WOW
On the downside
cheers :y
Bloody hell, can someone get this man a decent gearbox???  ;D
Shame about the whine, but top work mate :y.
serek
WOW
On the downside
cheers :y
you dont have luck at all  :-[
if you want I can swap my box for your with out any cost if you collect from me  :y :y
btw
its that box from Robsey??
if so I dont think hi would sold knackred box to you any way
RobseyMV6
Sure it's not the DMF you hear, they do this, different sound to the auto's this might be the whine.
not doubting robsey for one min guys please dont think that... These things happen!
I will change the box oil and ensure at correct level, drive it a bit and suck it and see :y
What mileage has your diff done? Autos deal with the torque differently, so giving it large without letting the set up bed in will highlight any weaknesses already present in the driveline :-\
Couple of further qs: did you fit the box single handed? Easy enough to put a load the input shaft, bending it slightly :-\ also did you check the level before firing it up :-\
Good effort BTW :y bout bloody time though ::)
yep fitted single handed, but nothing was forced, certianly not to point it would damage input shaft
yes, box had oil when fired up and driven... :D
Manual transmission oil :
EP80 CL4 original.. but after using it in winter , I decided Omegatoy was right .. 75W90 transmission oil better.. :y
Omegatoy
Quote from: cem on 21 June 2012, 09:17:54
:y :y :y
