central locking
Started by Michael2.6, 05 June 2012, 08:17:22
Michael2.6
Hi guys
Does anybody no where the central locking control unit lives
Looked for all over the car but failed to find it.
freecall666
Solar charger fitted.
If not Broke dont fix it..
Michael2.6
What exactly is the problem?
Michael2.6
Central locking sometimes works sometimes does not
It is not the keys in anyway
Single door lock or all?
Started with basics like battery in the key?
Michael2.6
When it does work it all works as it should
it is nothing to do with the key
spare key is new and coded to the car
it is not the batterys
Just because its new does not rule that out  ;)
Michael2.6
The spare key does not get used i am just using this to rule out the old key i have just put a new battery in it
I think the problem lies in the central locking control unit but can not get to find out where it is
I had a vauxhall movano pick up with the same problem it was the control unit
Central Locking unit is bullet proof on the Omega, can't say I've ever heard of one failing.
Its more likely one of the locking motors has failed/shorting, does the fuel filler flap lock with rest of the car?
Michael2.6
So what you are saying Tunnie that if one of the locking motors is goosed it knocks the rest out
are the motors wired in line or seperate?
Motors are in parallel
Michael2.6
And all control by the drivers door
tgm147
Do the doors lock then unlock straight away? Mine's doing this and it's a duff locking motor in the drivers door.
Car hasn't been locked in over 2 months  ::)
Quote from: Michael2.6 on 05 June 2012, 10:50:26
Behind driver`s kickpanel
