Author Topic: Manual gear knob removal.  (Read 1937 times)
Manual Elite V6
  • Swansea
  • Mechanic and MOT tester at a Jaguar specialist.
    • 1992 Cavalier GSi
« on: 05 June 2012, 13:33:25 »
Can someone tell me if the manual gearknob just twists off to remove or is there some other way? only asking as mine is looking a bit worn and would like to replace it.
Thanks.
1992 Cavalier GSi
2007 Astra Sri+ CDTi 150
Re: Manual gear knob removal.
« Reply #1 on: 05 June 2012, 13:42:19 »
Manual Elite V6
  • Swansea
    • 1992 Cavalier GSi
« Reply #2 on: 05 June 2012, 13:43:49 »
I guess that is one solution to use when I get a new one  ;D
1992 Cavalier GSi
« Reply #3 on: 05 June 2012, 13:45:57 »
It`s the only solution
  • Auckland
    • Mazda MPV
« Reply #4 on: 05 June 2012, 14:05:20 »
Alternatively...
Disconnect prop shaft from rear of gearbox (for easier access, might not be absolutely necessary), undo clamp on selector lever, undo 4no 6mm bolts & various bits of trim inside the car and the lever will come right out.
Probably about ten years since I took the gearbox out of my last car so the details are a bit hazy..........
« Reply #5 on: 05 June 2012, 14:23:01 »
Alternatively...
Just to remove the gear knob :o :o ::) :D
  • Auckland
    • Mazda MPV
« Reply #6 on: 05 June 2012, 14:41:54 »
Alternatively...
??? just trying to be helpful.........
I took my gearbox out to change the slave cylinder. While disconnecting the gear linkage I discovered how to take the lever out.
The gaiter was worn through & I intended to fit a new one but never got a round tuit  :P
