Fitted microphones
Started by Gr1msdale, 06 June 2012, 11:08:07
Gr1msdale
The interior light unit on my 02 2.2 CD version appears to have microphones fitted either side of the interior light unit. If this is the case then are there any other clues that I can look for to see if hands-free phone use is available in the vehicle? I have the CCCR2007 head unit fitted with no steering wheel controls allocated to mobile phone operation.
Quote from: Gr1msdale on 06 June 2012, 11:08:07
Sensors for the alarm mate ;)
Never heard of a cccr2007
Omegas came with ccrt2008 (with built in phone) or ccr2006 (or NCDC series or CDR2005)
Quote from: TheBoy on 06 June 2012, 19:48:27
But the mic (for my CCRT700) is central to my interior light, not either side  ;) ;)
Quote from: Andy B on 06 June 2012, 20:58:09
All factory fit mics are in same place :)
freecall666
CCCR2007 only thing can find on it is a cancer form about a test. ???
Solar charger fitted.
If not Broke dont fix it..
Quote from: TheBoy on 06 June 2012, 21:01:54
I know  ;) ;)
Dave DND
There was also a CART2007 that was used by GM around the time - but unusual to find one in an Omega ?
Radio & Decoding Technician
www.dndservices.co.uk
Quote from: Dave DND on 07 June 2012, 09:34:09
Never standard, and I believe never a factory option...
//TB will go through his brochures when he gets his lazy ass out of the bath...
Gr1msdale
 :'( Oops, sorry guys, I've clouded the waters somewhat. When I put my specs on and actually looked at the unit it is a CDR 2005! So, same question as previously but hopefully I've given sufficient correct information now for the boffins amongst you. APOLOGIES all round!
Quote from: Gr1msdale on 07 June 2012, 20:53:52
OK, no problem.
That unit has a lo-fi mono aux in, along with a mute, for phone kits.
If you have a little 4" aerial on saloon roof, its fairly trivial to add a phone kit.
Gr1msdale
Gr1msdale
 :'( Just checked the CDR 2005 VDO HU again and cannot see an aux socket anywhere. Is this an internal wiring job as the handbook refers me to Vauxhall fitters? I do have the stubby aerial, roof mounted. Could the devices either side of the interior light fitting possibly be alarm sensors and not microphones?
Quote from: Gr1msdale on 08 June 2012, 14:36:36
Reply #1 ^^^^^^^^^ ::)
If the car is prewired for phone, as described earlier, then fitting a phone kit is easier.  Thats a glovebox out job. If not prewired, bit harder, as radio has to come out, and loom modified.
