Author Topic: Exhaust manifold upgrade???  (Read 1998 times)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« on: 06 June 2012, 21:26:21 »
Hi from me...
I will be getting rid of my EGR kit and I also have a cracked exhaust manifold so....
In stead of blocking up the EGR port on the drivers side manifold, I have been thinking of fitting the manifolds from a 3.2.... Here's my question... Do they fit? Not just the heads but also the cats???
Re: Exhaust manifold upgrade???
« Reply #1 on: 06 June 2012, 21:29:55 »
Hi from me...
Yep, use existing cats
HockeyDave55
  • Milton Keynes
« Reply #2 on: 06 June 2012, 21:35:21 »
Hi from me...
Great :y
Anything I should know?
« Reply #3 on: 06 June 2012, 21:39:38 »
You`ll have to remove/blank off the SAI, reposition EGR and keep connected to prevent fault code and shave app. 5mm off the cat flange where it meets the manifold
« Last Edit: 06 June 2012, 21:46:01 by RobG »
HockeyDave55
  • Milton Keynes
« Reply #4 on: 06 June 2012, 22:00:28 »
I'm taking the EGR and the SAI out and fitting them both to the bin.
As far as shaving 5mm of the flange, that's easy and I guess it will be clear when I do it?
« Reply #5 on: 06 June 2012, 22:01:24 »
You can fit a little circuit to fool the ecu re. the EGR
HockeyDave55
  • Milton Keynes
« Reply #6 on: 06 June 2012, 22:02:54 »
:y yep, working on that :y cheers :)
