1997 radio/clock display
Started by mark3, 08 June 2012, 08:40:31
mark3
My radio and clock display was black yesterday, took the dash out to find bad connection at the multi plug but since then the outside temp is just showing dashed lines, will this come back on on its own once a temp signal is sent/recieved OR do i need to investigate further?
Quote from: mark3 on 08 June 2012, 08:40:31...... OR do i need to investigate further?
How about the connection to the temp sensor on te lower edge of your front bumper?  :-\
Sounds too coincidental to me, I'd revist that connector.
mark3
Quote from: TheBoy on 08 June 2012, 09:37:00
Yes i think your right, il have the dash out again later today and use some contact cleaner on it.....
mark3
I also noticed the left indicator warning lamp wasn't flashing but the indicators worked, so dash came out and sorted that problem, just bad connection at the bulb, BUT after much playing about with the connector for the radio and clock display i cant get any temperature reading to show at all so next step is the temp sensor...
