Insane Vauxhall Service Quote
Started by tunnie, 08 June 2012, 09:52:53
FatherT's Air-con stopped working again, we have his 2.2 MOT'd there as its always passed ok! They did a re-gas which fixed it last time, but it stopped working again, they checked it over and kindly provided this list from a "Visual Heath check"
Vehicle came in for Aircon inop Requires :-
Aircon radiator leaking £454.79
Bonnet cable snapped Requires :-
Bonnet cable £173.15
Carried out full  Visual Health Check on veh , also requires :-
Has slight wear in n/s steering idler  £190.19
o/s/r coil spring broken - non gen spring £146.39
Exhaust Manifold blowing , may also require studs drilling out £372.22
N/S/F Tyre on 1.6mm  on inner edge
O/S/F tYRE ON 2mm on inner edge
Rear tyres on 3mm  Budget tyres in stock £113.40 Each
Reset tracking £35.00
:o :o :o :o :o :o :o :o :o :o
A steering idler, £190!? A single coil spring £140!?! Christ!  >:(
Needless to say I've told FatherT to politely decline their work!
Funny thing is, they don't mention the cambelt, which is due!
Can anyone recommend suitable air-con rad? Sure can fix it for less than their quote!
henryd
Bloody hell Tunnie,I assume they provide the Vaseline free of charge :-X
other rides
Quote from: RobG on 08 June 2012, 09:56:58
http://www.autoairconparts.co.uk/vauxhall-omega-b-Car-air-conditioning-compressors-pumps-aircon-radiators-and-more/
£80 quid, much better for the rad. Cheers Rob  :y
Can the air-con rad be replaced on its own, does the evaporator need to be replaced too?
Quote from: tunnie on 08 June 2012, 10:03:14
If the evap needs changing, scrap the car :P
Quote from: TheBoy on 08 June 2012, 10:04:53
Take that as a no then  ::)
That said, aircon, cambelt, tyres, springs, all of which I can do, but maybe its time for FatherT to get a V8  :D
jonny2112
I had my first visual health check recently, also following aircon recharge, but the quotes weren't that scary  :o
Quote from: tunnie on 08 June 2012, 09:52:53
£1598.54...... :)
A sense of humour is a wonderful thing. ;D ;D ;)......but don't forget the cambelt.
More in the £60-£90 bracket......I think.
QuoteBudget tyres in stock £113.40 Each
What? For a ditchfinder, no doubt?
Quote from: Kevin Wood on 08 June 2012, 11:01:35
I know, 16's too, I paid less than that for mid range 17's!
FFS thats some quote - at least a large tub of Vaseline required :o :o
I've used these people for replacement radiators in the past - good quality and service - sure their condensors will be ok too :y
Quote from: dbug on 08 June 2012, 13:53:35
Cheers  :y
I think we will have to add up the little list of jobs, see whats what. Even DIY quite a few jobs need doing  :)
Quote from: Opti on 08 June 2012, 10:54:57
Bonnet cable £173.15   :o :o :o :o :o :o :o :o :o :o :o :o :o ::) ::) ::) ::) ::) ::) ::) ::)
£1598.54...... :)
:o   would that be inc VAT  :D
I'm not justifying the cost, but these prices will include labour and VaT :-\
No trade, or any other discount on the quoted work either, and the tyre prices are daft, like you said you could probably get Michelin ones for that ::)
If nothing else, you now know what's potentially up with it :y
