Author Topic: running on 3 cylinders  (Read 4649 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« on: 09 June 2012, 17:35:22 »
stopped at the lights and car was ticking over poorly.. it was running on 3 cylinders and on came the car/spanner light.
got home and had a look at what codes it had stored   p0303  cylinder 3 misfire detected
i take it that it might as well say  get your ass down to vx for a new dis pack...
Re: running on 3 cylinders
« Reply #1 on: 09 June 2012, 17:37:05 »
Check plugs first, see whats what.
When they do fail, it is usually on pot 3 or 4 from my experience. Mine failed at 105k, father T's at 120k
« Reply #2 on: 09 June 2012, 17:38:24 »
Check for oil/water in plug wells, and the state of the plugs.
Whilst coil pack is out, see if there are signs of breaking down (cracks, normally with rust marks, or arcing marks).
I use Bosch coil packs, bit cheaper, for my V6, but no idea whats available for those without a proper engine :P
« Reply #3 on: 09 June 2012, 17:39:22 »
Ohhh how the pish will be taken when I get a V8   :D
Steve B
  • Leicestershire
« Reply #4 on: 09 June 2012, 17:41:49 »
 ;D ;D ;D ;D ;D ;D ;D ;D
plugs 2 month old...new cam cover [vx] 3 weeks
gonna take a look in bit
hom many pennys are dis pack
« Last Edit: 09 June 2012, 17:44:49 by bigtimecube »
« Reply #5 on: 09 June 2012, 17:47:22 »
I've never owned a 4 pot Omega. UnLucky enough to have driven no end though. The 2.2DTi is the best of the small engines IMHO.
But the petrol 4 pots plod along nicely if you're Miss Daisy, and not too uneconomically.
« Reply #6 on: 09 June 2012, 17:48:21 »
Last v6 one I bought was around £75, so guess a ton for a quality pattern.
« Reply #7 on: 09 June 2012, 17:48:46 »
Especially when towing a dead V6 Elite
« Reply #8 on: 09 June 2012, 17:49:42 »
4 pot ones are around £100 on TC
« Reply #9 on: 09 June 2012, 17:51:15 »
Ideal job for it, as it won't pull the skin off a rice pudding, so a gentle tow ;)
« Reply #10 on: 09 June 2012, 17:54:13 »
Apart from when you get told off for driving too fast  :o
Although did take a while to get up to that speed, I'll defend the 4pots to the death. Underrated engines, doddle to work on,  DIY jobs on that a pleasure to do.
But V6 is not a proper engine, a V8 is  :D
Steve B
  • Leicestershire
« Reply #11 on: 09 June 2012, 17:58:16 »
and i take it [vx] is the best way to go with this part....
« Reply #12 on: 09 June 2012, 18:14:41 »
Couldn't be arsed to disconnect propshaft, thus that limits a tow to 50mph max.
There was an element of, knowing how bad your suspension is/was, I could easily turn you the other way as well ;)
« Reply #13 on: 09 June 2012, 18:15:11 »
VX if you have TC. Or any quality part like Bosch.
Steve B
  • Leicestershire
« Reply #14 on: 09 June 2012, 18:47:45 »
there you go the boy just been out there dis pack off plugs out back in and torqued up dis pack back on 25min
bet you cannot do that with your trolley ;D ;D ;D ;D ;D
plugs all good as expected [bosch] ones with 4 thingys on the end
no oil in the holes didnt expect none cos done new gasket
two of the rubber boots were split...
cars done 53000 .so looks like gotto blame dis pack
Page created in 0.019 seconds with 14 queries.
