Author Topic: Oversteer - front springs?  (Read 4492 times)
Re: Oversteer - front springs?
« Reply #15 on: 09 June 2012, 22:30:01 »
Ah, must have been the roll bar bushes you showed me then. Your welcome to bring it down if needed, see what we can find. :y
GmasterT
  • Cambridge
  • does that drifting thing...
« Reply #16 on: 09 June 2012, 23:03:38 »
I'd say rear issue if oversteer :) worth checking drop links all round too though :)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #17 on: 10 June 2012, 11:09:24 »
Thanks Chris. No you did see poly front bushes, but they were in my cr*p Delphis, which subsequently failed rear bushes, hence new Lems, and keeping the polys for when the front bushes go. I will probably not get round to looking at it for a couple of weeks as I am away and will use the 3.2 Elite:y
Shackeng
  • Ramsbury
« Reply #18 on: 10 June 2012, 11:11:02 »
Thanks G, front droplinks replaced last year, but will be checking rear springs etc. as advised above by TB. :y
Shackeng
  • Ramsbury
« Reply #19 on: 11 June 2012, 15:11:55 »
I've had it up on stands this AM and all springs and shocks appear sound on pax side, so perhaps it just needs another set up. I only notice this oversteer on one particular, downhill, RH, adverse camber corner, so maybe I'm just being fussy. :-\
« Reply #20 on: 11 June 2012, 18:56:47 »
What happens if you swap tyres, front to back?
Shackeng
  • Ramsbury
« Reply #21 on: 11 June 2012, 19:47:25 »
Funny you should say that, I have still got winter tyres fitted, which was the next issue to tackle. :y
