Author Topic: Oversteer - front springs?  (Read 4488 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 09 June 2012, 18:26:54 »
I've noticed in the last month or so that my TD Estate oversteers more than usual on a RH corner with slight adverse camber that I use regularly. I had it WIMmed about 5K ago, and there is no abnormal tyre wear, so I don't think it is the setup. The car is now on 115K and I suspect that the front springs may be due for replacement. Any thoughts? :-\
Re: Oversteer - front springs?
« Reply #1 on: 09 June 2012, 18:30:01 »
shocks as well?
Don't neglect rear - broken rear springs/shocks can oversteer.
« Reply #2 on: 09 June 2012, 18:31:04 »
Should add, AFAIK, my old TD saloon did 140k on original springs with no handling issues. :)
Shackeng
  • Ramsbury
« Reply #3 on: 09 June 2012, 18:34:00 »
shocks as well?
Good point, I'll check for breaks tomorrow, no sign of leaks from the shocks, and certainly the front end doesn't 'bounce' when checked for failed shocks, and which I would change with springs as a matter of course. :y
Shackeng
  • Ramsbury
« Reply #4 on: 09 June 2012, 18:36:32 »
My TD Estate has shifted some heavy loads, so I would not be surprised if it was time to change Zebedee and his pals. :y
« Reply #5 on: 09 June 2012, 18:41:31 »
shocks as well?
Considering the price of GM springs, and how good I think they are, I would only change fronts if they developed a fault.  Hmmm.  I changed my MV6 fronts around 30k ago, as ride height was shafted, and on removal, one was longer than other (but neither broken)
Shackeng
  • Ramsbury
« Reply #6 on: 09 June 2012, 18:47:42 »
shocks as well?
« Reply #7 on: 09 June 2012, 18:55:58 »
Sorry, that didn't make sense, did it.
They are normally really good/reliable, if a tad soft. But when they fail (either break or dramatic length change), its normally fairly obvious.  Additionally, I am traditionally quite hard on springs/shocks/suspension/steering. Roundabout City doesn't help.
Shackeng
  • Ramsbury
« Reply #8 on: 09 June 2012, 19:18:26 »
That comes as a complete surprise. ;D ;D ;D :y
Omegatoy
  • UK
« Reply #9 on: 09 June 2012, 19:32:40 »
drivers side on my old TD estate was consierably softer than passenger side, did post up on here upon changing the slight pull to the right which had aways been there was completley cured,
y theory is as car has mostly just the driver in it, the springs do degrade!!
« Reply #10 on: 09 June 2012, 19:37:34 »
Seems to be passenger side I wreck first. Probably bloody roundabouts...
Omegatoy
  • UK
« Reply #11 on: 09 June 2012, 19:40:05 »
it been proven you tend to go faster round a right hand bend than a left, because you feel safer!! on left hand bend you are closer to the road surface, so you go slower,just in case it falls over!! hence you wear left hand quicker!! :y
Shackeng
  • Ramsbury
« Reply #12 on: 09 June 2012, 20:30:28 »
If anything has gone on mine its pax side, and I still suspect the front :y
« Reply #13 on: 09 June 2012, 21:24:26 »
Any folding or tucking sensations from the front? Especially when manoeuvring on full lock when parking. Check rearward wishbone bush if so. Iirc you have polly fronts?
Shackeng
  • Ramsbury
« Reply #14 on: 09 June 2012, 22:15:34 »
Not pollyed at present (on the shelf on stand-by), as new Lems fitted last year, so I doubt the rear bushes have gone yet, and I have not noted that effect. :y
