Breather Tubes
Started by Raymienets, 10 June 2012, 15:29:52
Raymienets
Uploaded with ImageShack.us
I remember disconnecting the T piece but cannot remember where I disconnected it from. Cheers
Multi-rams, at the bottom of the trumpets  :y
Raymienets
Quote from: tunnie on 10 June 2012, 15:32:14
See 2 holes ar bottom of trumpets, I appear to have lost a tube that connects to the T piece. Remember disconecting it.
amba
They are actually vacuum pipes and as said connect to a T peice by the mulirams.
Sure there is a proper picture in the maintenance guide somewhere showing them
The Red Baron
if i remember correct, one goes to the T & the other goes to the vac tank/res at the bottom.
Raymienets
Ah did not know what they were called. LOL will check maintenanace section thanks.
T piece goes to multi ram on front inlet.
The ends go to the vac tank at the bottom of inlet.
Raymienets
Many Thanks much appreciated. Could not remember where I disconected it from.
The Red Baron
Quote from: amba on 10 June 2012, 17:27:32
There is V6 engine bay vacuum pipes (it is a bit difficult to find because vacuum is spelled 'vaccum' in the title)
Raymienets
