Author Topic: Vibration felt threw the gearstick  (Read 2024 times)
tigers_gonads
  • Online Online
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 11 June 2012, 08:21:37 »
As above.
Depending on the road surface, i'm getting a hell of alot more vibration threw the gear stick then normal.
The vibration is consistant regardless of whether the car is in gear or just coasting along with the gearbox in neutral so I don't think it is the gearbox / clutch  :-\
Anybody come across this before ?
Re: Vibration felt threw the gearstick
« Reply #1 on: 11 June 2012, 08:33:21 »
out of balance prop shaft ......  :-\ :-\
tigers_gonads
  • Online Online
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 11 June 2012, 08:40:19 »
Oh yeh, a little update on this that might help  :-[ :-[ :-[
Had a whine from my transmition a few months back.
Turned out that the gearbox had very little oil in it.  ::) :-[
It has been topped up and some wyns gearbox additive added.
No problems with the gearchange of anything.
Tbh, its one of the best changes on a mig i've ever felt  :)
I_want_an_Omega
« Reply #3 on: 11 June 2012, 08:46:58 »
What's the status of your LPG probs Steve?
Haven't seen anything - but may have missed it of course.
tigers_gonads
  • Online Online
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 11 June 2012, 09:27:30 »
Which one  ;D ;D ;D
Poped to see daz a couple of weeks back.
Still got Ht problems (burnt a couple of leads out while hammering it back from stoke  ;D)
Daz changed my block thermostat and radiator so at least it runs cool now  ::)
That Icv you sent me seems to have sorted out the idle, thanks  :y
I've just recieved some new 10mm twin core Ht leads of ebay this morning so i'll fit them and clean the plugs up and see how it goes.
If they are decient, i'll stick a recomendation on here because I can't fault the service upto now  :)
I_want_an_Omega
« Reply #5 on: 11 June 2012, 09:32:33 »
fingers crossed  :y
tigers_gonads
  • Online Online
  • Kinston Upon Hull
  • Sill breathing
« Reply #6 on: 11 June 2012, 12:26:07 »
How do I check for this for this andy ?
« Reply #7 on: 11 June 2012, 14:29:08 »
rear tires lifted, fronts blocked, traction off,  4 or 5th gear ..
« Reply #8 on: 11 June 2012, 21:01:38 »
Are there signs of a missing weight? There's specific machine for testing one.  :y :y
tigers_gonads
  • Online Online
  • Kinston Upon Hull
  • Sill breathing
« Reply #9 on: 11 June 2012, 21:05:00 »
Where abouts are these weights on the shaft ?
I'll have a look around later in the week when I sort out the flipping spring that I knackerd this morning  :'( :'(
« Reply #10 on: 11 June 2012, 21:10:21 »
They're normally flat plates 1/2"-ish wide x 1 1/2" long spot welded to the shaft.
tigers_gonads
  • Online Online
  • Kinston Upon Hull
  • Sill breathing
« Reply #11 on: 11 June 2012, 22:00:07 »
Cheers Andy  :y
Need to sort out these springs first tho  :y
I had the back end rather loose round a roundabout this morning  ::) :-X  ;D
