Author Topic: Pre facelift estate rear springs  (Read 4244 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 11 June 2012, 19:15:57 »
I need a pair quick and cheapish if possible  :'(
Snapped one in half this morning bouncing  driving slowly over a speed bump  :-[
Can anybody recomend any ?
Are they left / right handed or universal ?
Tia
Re: Pre facelift estate rear springs
« Reply #1 on: 11 June 2012, 19:20:05 »
SL or standard
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 11 June 2012, 19:23:33 »
SL or standard
Standard.
Car is a cd version
« Reply #3 on: 11 June 2012, 19:24:17 »
KYB from Sutton Auto Factors?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 11 June 2012, 19:32:43 »
Any idea on price ?
Can't seem to get access to there buy online part of there website (tho that meens break all when i'm pressing the buttons  ::))
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #6 on: 11 June 2012, 23:08:29 »
One single spring no good to anyone. Always change springs in axle pairs.
Plus it's a continuos width wire. Omega ones taper at the ends.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 11 June 2012, 23:11:45 »
Tbh, I was going to change both anyway chris  ;)
I'm not quite that skint  ;D ;D ;D
Would the taper be a problem ?
« Reply #8 on: 11 June 2012, 23:20:36 »
Although it does say 10 available. Missed that. ;D
Why not check? http://www.kyb-europe.com/catalogue.asp
They are/should be progressive rate spring. Single width wire will not give a progressive rising rate.(gets stiffer the more it's compressed)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #9 on: 11 June 2012, 23:23:43 »
Tbh, I could do with them a little bit stiffer because of the gas tank and the amout of weight I carry in the back  :)
I'll have a look in the morning though  :y
Cheers Chris  :)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #11 on: 12 June 2012, 13:37:06 »
Ordered  :y
Thanks for the help lads  :-*
robincdx
  • St Neots, Cambs, UK
    • 2003 Omega 2.2DTI CDX
« Reply #12 on: 13 June 2012, 16:06:10 »
Ordered  :y
(Plus it's a continuos width wire. Omega ones taper at the ends.)
Did these turn out to be the correct tapered at the ends springs?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #13 on: 13 June 2012, 18:21:20 »
Ordered  :y
According to the ebay advert, they should be tapered at both ends.
They should be here thursday or friday
« Reply #14 on: 13 June 2012, 20:02:36 »
Can always check here
Select catalogue at the top and...
Actually, here you go.
