Author Topic: Sintra front hub torque setting  (Read 1782 times)
Cav9_4
  • Sutton-In-Ashfield,Notts
  • 2003 Omega 2.6 Elite
« on: 10 April 2008, 16:19:35 »
Hi,anyone idea what i could be,just looked at Omega,320 Nm,looks like having to buy a new torque wrench too!
« Last Edit: 10 April 2008, 16:19:58 by cav9_4 »
Re: Sintra front hub torque setting
« Reply #1 on: 10 April 2008, 16:21:46 »
It's times like this when I do a bit of mental arithmetic and work out how far a long the breaker bar a 15 stone bloke needs to be...   :-X
Big Fra
  • Motherwell
« Reply #2 on: 10 April 2008, 16:29:07 »
lol  ;D
« Reply #3 on: 10 April 2008, 16:49:38 »
Its a very different setup to the Omega being front wheel drive with CV joints.
So:
Wheel bearing unit to steering knuckle bolts (3 off) 130Nm with thread lock.
Cv joint to wheel bering unit retaining bolt (1 off) 160Nm.
When fitting the unit, I seem to recall that the ABS senosr wire needs to be at 6 Oclock so check its location when you take the old one off.
« Reply #4 on: 10 April 2008, 16:50:16 »
From my experiance, a lot more than 320Nm.... ::)
« Reply #5 on: 10 April 2008, 17:51:08 »
235 ft.lb. 210 lb of bloke, so about a foot and a bit along the breaker bar.  :y
« Reply #6 on: 10 April 2008, 18:55:28 »
Yes but, only a fool pushes down with thier full boy weight on a breaker bar........ :o
« Reply #7 on: 10 April 2008, 19:13:11 »
Yes but, only a fool pushes down with their full boy weight on a breaker bar........ :o
Was that a clue or a typo?   ;)
« Last Edit: 10 April 2008, 19:13:35 by Andy_B »
Debs.
« Reply #8 on: 10 April 2008, 19:15:30 »
 ;) Pssst: let`s torque about it!  ;D
Page created in 0.024 seconds with 16 queries.
