Author Topic: More car porn  (Read 5066 times)
More car porn
« on: 12 June 2012, 16:20:29 »
Courtesy of one of my kit car mates... :-*
http://www.youtube.com/watch?v=hJ_07eHXTPw
Re: More car porn
« Reply #1 on: 12 June 2012, 16:32:06 »
Oh I bet that's fun with a capital F!
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: More car porn
« Reply #2 on: 12 June 2012, 16:33:04 »
Good job those straps are tight  :D :D :D
Re: More car porn
« Reply #3 on: 12 June 2012, 16:59:46 »
Perhaps a bit too much so.. I note it's had a few car-scenery interfaces. Then again, can happen to the best of us. :-[
Re: More car porn
« Reply #4 on: 12 June 2012, 17:51:52 »
Bike derived 2.4 v8   - wassathen ? :-\
Re: More car porn
« Reply #5 on: 12 June 2012, 18:26:11 »
Two 1200cc bike engines on a common crank ;) There's a few on the market I think, all hideously expensive, but there's some waffle about one of them here: http://www.evo.co.uk/carreviews/evocarreviews/49734/caterham.html
Re: More car porn
« Reply #6 on: 12 June 2012, 19:37:35 »
Very interesting,thanks. :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: More car porn
« Reply #7 on: 12 June 2012, 20:33:19 »
Christ almighty,that must be mental with that power to weight :o :o
other rides
dazzerM
  • Reading
  • Mokka 1.7CDTI, BMW 120D Shadow (It’s a work car)
    • Which ones closest
Re: More car porn
« Reply #8 on: 12 June 2012, 20:35:55 »
Oh yes please  :)
Darren
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: More car porn
« Reply #9 on: 12 June 2012, 20:47:16 »
I wonder if that would fit under the bonnet of an omega  :D
Re: More car porn
« Reply #10 on: 12 June 2012, 21:51:02 »
Power to weight ratio might be a tad dissappointing compared to the Caterham :D
Gorgeous noise though  8)
Re: More car porn
« Reply #11 on: 12 June 2012, 22:28:54 »
Very nice, is it available in auto?............... :D :D :D
Re: More car porn
« Reply #12 on: 13 June 2012, 10:16:46 »
Saying that, I'd be surprised if you need your left foot much with that gearbox once it's moving. 8)
Re: More car porn
« Reply #13 on: 13 June 2012, 10:46:25 »
Why would the cam chain pull the oil to the top end, any more than the bike version would... ? :-\  Could understand it for longitudinal mounting reasons, as opposed to across the frame.
And I didn't understand the bit about the H pattern box being preferable to a sequential.
Article explanes the low(for a bike engine) rpm limit though. Pussys! :D
Re: More car porn
« Reply #14 on: 13 June 2012, 12:06:39 »
Yep, a bit of journalistic licence there (you know, the type you find round the back of a male of the bovine species).
If it's dry sumped, you just scavenge the oil from where it ends up. I'd be very surprised if the chain drags much oil up from the bottom end if the crankcase is being evacuated effectively by the scavenge pump, but if it is, surely you'd just add a scavenge pipe from the head that's getting drowned in oil?
If it takes 20 minutes of running for the problem to occur, then the rate of oil pickup is very slow. It would surely be trivial to arrange a way for that small amount of oil to drain back, be scavenged, or not end up there in the first place.
I could quite imagine there would be other challenges with making a central cam chain work on a V8, though, and I suspect that's why they switched. ;)
Yep. more BS. If you're whinging about driveability what are you doing sitting in a seven that revs to 10k+? Get a job at "Car and Caravan" instead. ;)
I got talking to a guy at a Westfield sprint at Goodwood who was campaigning a bike based V8. Engine owed him £16K, apparently.  :o Did it ever accelerate off the line, though. :D
« Last Edit: 13 June 2012, 12:08:11 by Kevin Wood »
