Author Topic: omega front springs  (Read 1923 times)
megaelite
    • a car
omega front springs
« on: 12 June 2012, 22:29:52 »
i think the front spring on my elite has snapped and was wondering how hard it is and whats involved, im thinking of changing the complete strut rather than just the spring
cheers for any help
RobseyMV6
  • west sussex
Re: omega front springs
« Reply #1 on: 12 June 2012, 22:36:04 »
Two bolts that hold hud on that you will clearly see when wheel off and undo nut on top in engine bay, easy job.
megaelite
    • a car
« Reply #2 on: 12 June 2012, 22:41:10 »
lovley jubley, cheers
« Reply #3 on: 12 June 2012, 22:41:59 »
And the drop link to disconnect. Start with that first, as it might be seized.
Always replace suspension parts in axle pairs btw. Lopsided and uneven performance will result otherwise.
Then set up after, attempt to measure camber first to replicate after. See guide.
megaelite
    • a car
« Reply #4 on: 12 June 2012, 22:48:02 »
:y, i cant be arsed with all that, looks like it will be going to the garage, i may change the strut and get a tyre place to sort the rest
« Reply #5 on: 12 June 2012, 23:02:41 »
tyre place no good, they'll shaft you over, and you'll still get bad handling and shoulder wear, see Wheels in motion web site. Although the guide is quite easy, and will be more use than "a tyre place" of the usuall tracking fixes all caliber. The omega needs full geometric set up, for camber, caster and toe. ...just for info. :)
Where are you, roughly?
megaelite
    • a car
« Reply #6 on: 13 June 2012, 08:01:16 »
im in stoke
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
« Reply #7 on: 13 June 2012, 10:36:36 »
Easy job, took me less than an hour at the weekend to remove both front shocks off my V6
drop links are probably the trickiest bit, thay can get a bit thread rusty
« Reply #8 on: 13 June 2012, 12:25:03 »
im in stoke
you'd better speaking to Daz....
http://www.omegaowners.com/forum/index.php?action=profile;u=12562
...for any work IMO.
A fellow Stokie. Might be worth a pm...?
« Last Edit: 13 June 2012, 12:39:14 by chrisgixer »
megaelite
    • a car
« Reply #9 on: 13 June 2012, 15:07:59 »
im in stoke
already on it lol, just waiting for a reply, :y
