Wood be gone
Started by omega3000, 13 June 2012, 09:27:47
So all the wood taken out and sprayed in my choice of colour ... Not too bad a job to do just a bit fidley but once its taken to bits a few times it gets easier  ;D I must say how very well the controls and mechanisms are well put together ..
When its all in bits it looks a bit daunting thinking how am i ever going to get this back together  :o
The bits i finally got off ... pheeww  :)
That looks to be a great job 'dust - well done. 8) :y
Quote from: Dummkopf Den on 13 June 2012, 09:36:33
Thanks den , never thought i would see it back together after seeing what i had to re assemble  :o deep breaths and plenty of breaks , took me 2 days allowing paint to dry ...quite pleased with the results considering im no expert  :)
duggs
Personal choice once again...To be honest, I think you've demoted the appearance to that of a bog standard basic GL type model.
Spraying imo would have been a good idea IF some form of colour/design was introduced BUT black just seems ermmmm...well plain and cheap looking I feel...but there again...I ain't driving her !
Quote from: eatmydust on 13 June 2012, 09:41:31
good practice.. patience always pays back :y   (well most of the time ;D )
and the next step is ......
a manual stick   ;D :y
Quote from: cem on 13 June 2012, 11:16:48
Only problem i had was fitting my hand through to release the pull bar  :( oh and trying to refit without scratching it  :)
x25dt
Personaly I'd rather the wood touch  :y
Quote from: cem on 13 June 2012, 11:18:10
It will be but not just yet , gearboxes are a doddle to change  ::) :-X
honestly the black painted trim looks better than the outdated fake woody woodpecker trim ;D
duggs
#10
Nope !    Been driving since 1979, first 5 cars from that date had ermmmmm black trim. Ford, Vauxhall you name them...black.  The timber look finish, IF you could afford it, was a luxury back then and in my opinion it still is now. Granted it isn't real timber BUT at least it demonstrated a bit of style/class.   Just plain black does neither of those !
henryd
Quote from: duggs on 13 June 2012, 14:07:08
I'm in the same camp as you,must be an age thing :-X,but each to there own and a nice job done by the looks of it
other rides
duggs
THAT Henryd..is a VERY good point. ...but with age..comes wisdom !     LOL !
OmegaAnglesey
Very Nice Indeed!
I wouldn't say it looks like a GLS, If anything it looks more like an MV6  :y
Does's this mean you have done the bits of wood on the doors ?
Plastic wood looks really low rent. I'm wth EMD on this one. :y. It's the same with my MV6.......silver spray paint won't fool anyone with two or more brain cells to rub together. :'(
Now if Vauxhall used the same wood as a DB9, I'd say keep it.  :y
Back in the late seventies I owned a Triumph 1500.....and a Triumph 2500S. Both used real wood. :) :) ;)
