Pages: [1] 2 3  All   Go Down
Author Topic: Ramps.  (Read 7977 times)
Ramps.
« on: 13 June 2012, 10:53:01 »
How do I get my MV6 up a set of standard ramps?.....when the overhang both front and rear stops me. :-\
Do I need ramps with a more gentle incline?.
Re: Ramps.
« Reply #1 on: 13 June 2012, 11:00:41 »
AA has extensions.
Or I have a 3 ton jack that is man enough to lift the car high enough, so ramps can be place under.
Re: Ramps.
« Reply #2 on: 13 June 2012, 11:03:31 »
AA has extensions.
I'm intrigued.....How do they work?
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
Re: Ramps.
« Reply #3 on: 13 June 2012, 11:03:59 »
put some bricks or timber in front, drive up onto them first to raise the car slightly. should give you enough clearance for ramps.
remember to put them back when you bring the car back off !
Re: Ramps.
« Reply #4 on: 13 June 2012, 11:15:51 »
AA has extensions.
a ramp onto the ramp basically. I guess they also help stop the ramp sliding away as the wheel hits them.
Re: Ramps.
« Reply #5 on: 13 June 2012, 12:26:24 »
AA has extensions.
like this ......  ;)  ;)
Re: Ramps.
« Reply #6 on: 13 June 2012, 13:23:36 »
AA has extensions.
Thanks Andy. I suppose  the design of these ramps dates back to a time when the average car didn't sit as low as they do today. I'll wager an old Mini, Moggy or Marina would drive straight on.
Re: Ramps.
« Reply #7 on: 13 June 2012, 13:35:31 »
Probably, but my extentions dates back to when I wanted to drive my Senator up my ramps ...... same problem, the lower edge of the bumper hit the ramp way before the wheel even looked at the ramp.  :y :y
Her Smart will drive straight up the ramps because the wheels sit at each corner, but I still use the extentions because it gives a lower angle of attack & the ramps are less likely to get pushed forward as you drive up.  :y
Re: Ramps.
« Reply #8 on: 13 June 2012, 13:59:31 »
Tried the ramps with Mrs Opti's 53 plate Corsa. Rear......No problems. Front.......No chance.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Ramps.
« Reply #9 on: 13 June 2012, 14:52:22 »
I use bits of 6" X 3" timber resting on the second or third rung up.  :o  I hang my ramps on the garage wall when not in use and store the timber with them. I'm not condoning this as good practice though as the second or third rung has a serious bow in it now.  ::)  Andy's mod is the safer method.  :y
Re: Ramps.
« Reply #11 on: 13 June 2012, 16:09:37 »
Someone stole your design andy  ::) ???
http://www.ebay.co.uk/itm/Low-Entry-Metal-Car-Ramps-2-0-Tonne-2000kg-NEW-/300711334961?pt=UK_Lifting_Moving_Equipment&hash=item4603cad431
....but why make the extensions so narrow? :-\ I sincerely hope that  Andy B patented his invention. :y
Re: Ramps.
« Reply #12 on: 13 June 2012, 16:12:14 »
If only ...........  :'( I could've been a millionare!  ::)
Re: Ramps.
« Reply #13 on: 13 June 2012, 17:36:37 »
Sadly they skipped on materials and made them very narrow as you spotted mr opti  :(
Re: Ramps.
« Reply #14 on: 13 June 2012, 18:09:44 »
Thats not a bad price for a set of ramps plus extensions.
The extensions dont need to be overly wide, they are only driven over as a transition from ground to ramp top.
Pages: [1] 2 3  All   Go Up
Page created in 0.024 seconds with 20 queries.
