Author Topic: Engine trouble  (Read 7930 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Engine trouble
« Reply #15 on: 14 June 2012, 15:56:13 »
I was dowm your way at the weekend too :(
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
Re: Engine trouble
« Reply #16 on: 14 June 2012, 17:27:15 »
It was working at the weekend! *facepalm*
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
Lampynoiseboy
  • SE Essex
Re: Engine trouble
« Reply #17 on: 17 June 2012, 16:46:47 »
Well
Having had my guy read the codes as stated earlier, forgot to mention he did pull some bits off & put them back again. yes, I know that's vague, but I know less than nothing about engines. His first suggestion was also MAFF sensor, but he wasn't convinced hence the post on here.
However, since then it's been perfect, so guessing it was just loose or had shite in it?
Lampynoiseboy
  • SE Essex
Re: Engine trouble
« Reply #18 on: 19 June 2012, 18:27:40 »
And he does normally know what's what straight away, was just unwilling to spend £140 of my money without being sure!
Fair I thought.... :y
Lampynoiseboy
  • SE Essex
Re: Engine trouble
« Reply #19 on: 13 July 2012, 19:18:25 »
Well
New maf sensor today thank to cavectra centre......still same issues
Any thoughts?
Lampynoiseboy
  • SE Essex
Re: Engine trouble
« Reply #20 on: 06 August 2012, 09:59:39 »
Still playing silly buggers, but seems to be only when under a 1/4 tank of fuel, keeping it over that makes it behave.
I'm thinking fuel pump, any opinions for/against?
a2reed
  • Battersea London
Re: Engine trouble
« Reply #21 on: 06 August 2012, 10:11:20 »
C0uld be dispack ... that would give intermittent performance similar to MAf sensor going ... I had the same on mine ...codes were saying MAF but it turned out to be dispack and by the time I got it out you could clearly see it was buggered... so if you have a spare 2 hours and don't want to waste any more dosh you could take out the dispack and check it
although the evidence with the extra fuel in the tank points away from that ... Blocked fuel filter/ fuel pump ???...I would still check the dispack
Re: Engine trouble
« Reply #22 on: 06 August 2012, 10:51:30 »
3.2 doesnt have dispack,has a coil pack per bank.worth doing the usual visual checks of coil packs,plug wells etc. Depending on service history,may be worth changing plugs,fuel filter etc.
Ideally a tech2 session to save on guesswork. Did I give you a number for a bloke local to you ?
