Author Topic: Help coolent leak,  (Read 1400 times)
Greebo12
  • staffordshire
Help coolent leak,
« on: 15 June 2012, 17:03:54 »
I have a beautiful omega 2.2 petrol  2002 model, over the last two day she has lost two litre of coolent but i cannot see any leak or wet patches.
i have check the oil and it is fine does any body have any idea's is it going to be expensive ??
What should i do
next problem i am in Spain at the moment  :'(
also this may be nothing to do with the water like but when you start the car after it has been off for over a hour it runs lumpy for the first 30 seconds your it to rev the car its as if the car is not getting enough fuel
« Last Edit: 15 June 2012, 17:10:59 by Greebo12 »
Varche
  • middle of Andalucia
    • Golf Estate
Re: Help coolent leak,
« Reply #1 on: 15 June 2012, 18:39:50 »
Might be the heater bypass valve. HBV.
Situated at back of engine , in front of steering wheel (RHD car). It joins 3 pipes together and are prone to the membrane failing. Looks like a miniature star ship enterprise.
Wherabouts are you in Spain?
« Reply #2 on: 15 June 2012, 18:50:03 »
What should i do
If HBV is OK, leave car overnight, before starting engine remove plug #4 and check for coolant on piston crown
« Last Edit: 15 June 2012, 18:53:07 by RobG »
