Author Topic: PDF encryption  (Read 900 times)
omegod
  • liverpool
    • 2017 Seat Ateca
PDF encryption
« on: 19 June 2012, 13:43:50 »
I need to send confidential documents that have been scanned into a PDF but want to password protect or encrypt it for securtity, is this possible???? On the works CITRIX system at the moment if that helps.
Also sent this problem to our IT dep't so see if OOF can beat them to it!
Re: PDF encryption
« Reply #1 on: 19 June 2012, 13:49:52 »
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: PDF encryption
« Reply #2 on: 19 June 2012, 14:38:02 »
Is the information in the document classified?  I hope not if it is on a CITRIX system.  In which case I am guessing it is of commercial value?  If it contains information of a personal nature for you or someone else then by law you must take all reasonable precautions to safeguard the information.  How much security you put on that depends on the impact level of the personal data being transmitted, the ICO can give you some guidance on that.
You can password protect against modification but it wont stop anyone copying the information and it would be pretty easy to intercept and thus read if you had the correct resources and the will.
If you wish no one but the recipient to be able to view the file you will have to encrypt it, PGP is ok for most purposes.  Regardless of what program you use make sure it has a public and private key arrangement.
I guess also your CITRIX system has some kind of external web portal?  If not then you will probably need assistance and permission to export on to a system which does.
Where I work, this type of endevour is pretty labour intensive.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: PDF encryption
« Reply #3 on: 19 June 2012, 15:11:12 »
Pretty sure Adobe Acrobat will do what you need assuming you have access to it.
TuBy's new whipping boy.
omegod
  • liverpool
    • 2017 Seat Ateca
Re: PDF encryption
« Reply #4 on: 19 June 2012, 16:21:57 »
I managed to pop it into a winzip file and then encrypt it with a password also. I/T stuff gives me migraines!
