Author Topic: Rumbling sound at rear  (Read 4732 times)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« on: 19 June 2012, 21:20:09 »
Hi has a rumbling sound from rear when going round a right hand corner, as if the mud flap is hitting the ground but is not that. any ideas what it could be? had a look at wheel bearing and feels fine.
thanks for looking
Solar charger fitted.
If not Broke dont fix it..
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
Re: Rumbling sound at rear
« Reply #1 on: 19 June 2012, 22:21:24 »
Any oil in the diff? Old rear tyre gone out of shape or hardened with age? Might even be an engine mount thats shot?
« Last Edit: 19 June 2012, 22:24:04 by sticka_v8_init »
Those are my principles, if you don't like them I have others.
freecall666
« Reply #2 on: 19 June 2012, 22:24:01 »
i will check that ok tomorrow, dont had diff open to see yet. only dose it on drivers side rear, well thats the one i can hear any way.
kev2b4
  • Luton, Beds
    • 2.5 CDX ,2.5 tourer
« Reply #3 on: 20 June 2012, 10:58:58 »
rumbling sound at rear ime has usually been due to various ales/indian meals -- (promised myself would resist-- but couldn't (somebody has to!)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #4 on: 20 June 2012, 11:06:00 »
Shocks n springs ok?
RIP Paul Lovejoy
cube
  • Leeds
« Reply #5 on: 20 June 2012, 11:38:19 »
Exhaust back box ??
After just putting mine back on the road, I had a rumbling noise at the back, the back box had come out of it's rubber mountings some how, any way re-fitted it and now no noise  :D
Worth checking  :y
2.2 petrol GLS estate
« Reply #6 on: 20 June 2012, 13:30:19 »
Near side rear wheel bearing.
freecall666
« Reply #7 on: 20 June 2012, 21:57:52 »
ive checked the oil in dif that was ok springs on both sides are fine no broken bits, tyre is fine no splits or hard parts, exhaust box has a few inches away from the frame. shocks work with no sounds. only part not looked at is the rubber mounting on top of the shock, but to day there was no rumbling on drive side rear turn'd into a clunk? checked bearing out with a stethoscope and no adverse sounds from both bearings.
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #8 on: 21 June 2012, 06:17:50 »
MOT'd SWMBO's Zafira yesterday and the tester asked if I had heard rumbling at the rear..... not that I remember.
He tells me that Vx generally suffer from rear tyres going out of shape, which was the case this time, but he warned that if you hear the rumbling and go to a garage, chances are they will tell you its the bearings!
Advice given: Change the rear wheels to the front, if the noise moves forward it's the tyres and if not then it's possibly bearings ::)
AKA - Mr Bracket
pauls
  • By the sea minehead
    • Bmw x3
« Reply #9 on: 21 June 2012, 09:01:11 »
I dont know if its the same problem but I was getting a clunk/knocking sound from the back of my car and after a lot of investigation and changing bits I changed the top rubber mounts on my rear shocks and the noise has gone. I belive it was the rubber +metal collar that goes thru the car. Hope this helps.
freecall666
« Reply #10 on: 21 June 2012, 14:50:26 »
managed to look at the top of the shocks and the rubbers are split, so will get some new one's see if that sorts it out. pass side looks ok but will change it aswell. :y
bigegg
  • Leeds
    • MV6 RIP - Lexus GS300 '99
« Reply #11 on: 21 June 2012, 16:13:22 »
Check if the handbrake shoe has come loose in the drum
Carpe Incendium
freecall666
« Reply #12 on: 21 June 2012, 22:37:34 »
checked that, has new kit from mot, had to repair fixing plate. :y
