Author Topic: intermittent cutting problem on lpg..  (Read 1311 times)
« on: 21 June 2012, 19:18:45 »
today we tried to solve this intermittent cutting problem on friends mondeo..
mechanics claimed its the coil and cables..  I said it wont be as the car is  at 70K kms.. ???
I opened the battery box for measuring voltages and bingo.. the original battery leak some acids..
I said before everything lets change this .. car owner and mechanics said lets try coil first.. ::) ::)
pay the bill , brand new coil in and result the same ;D
then they decided to try 50 amp (original battery 43 amp) ..  a bit better but still there's problem (actually problem was not visible until we started the AC and lights) ..
later tried 72 amp battery .. and problem gone.. :)
and I said alternator and chasis needs checking also.. because alternator charging measurement is in the limit..
mechanics :0 cem :1  ;D
thanks Kevin for the detailed writing :y
« Last Edit: 21 June 2012, 19:20:38 by cem »
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
Re: intermittent cutting problem on lpg..
« Reply #1 on: 21 June 2012, 19:21:39 »
mechanics :0 OOF Member :1  ;D
Fixed that for you Cem  ;D ;D ;D :y
« Reply #2 on: 21 June 2012, 19:32:24 »
 :y :y :y
