Author Topic: Help with these Fault codes please  (Read 3789 times)
markspark
  • Bolton
« on: 22 June 2012, 20:21:20 »
Hi after driving through a large puddle today my check light has come on and the car is in limp mode  switching the car off then back on again it clears for a short time i have read the codes and here is what its saying
P0195 - © Critical system malfunction
P1125 - (3) Critical system malfunction
P1590 (4) Engine Running Signal Low input
can you help me as to what they mean as i need the car in the morning  :(
markspark
  • Bolton
Re: Help with these Fault codes please
« Reply #1 on: 22 June 2012, 20:23:07 »
sorry forgot some info the car is a 2.2 DTI Y reg
markspark
  • Bolton
« Reply #2 on: 22 June 2012, 21:07:41 »
Where the heck do i start with these please
P0195   Engine Oil Temperature Sensor Circuit High Input
 P0195   Engine Oil Temperature Sensor Circuit Low Input
 P0195   Critical system malfunction 2 (refer to checking procedure: trouble code description)
 P0195   Critical system malfunction 1 (refer to checking procedure: trouble code description)
P1125   Boost Pressure Solenoid Valve High Input
 P1125   Boost Pressure Solenoid Valve Circuit Open
 P1125   Critical system malfunction 1 (refer to checking procedure: trouble code description)
 P1125   Critical system malfunction 2 (refer to checking procedure: trouble code description)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #3 on: 22 June 2012, 21:49:39 »
other rides
markspark
  • Bolton
« Reply #4 on: 22 June 2012, 22:02:19 »
Have a look here for your engine :y
http://www.omegaowners.com/forum/index.php?topic=90667.0
this is where i got the above info from but it dont really guide as to where i need to start looking
markspark
  • Bolton
« Reply #5 on: 22 June 2012, 23:43:25 »
where is the Boost Pressure Solenoid Valve and the Engine Oil Temperature Sensor
« Reply #6 on: 23 June 2012, 05:45:53 »
Not a common engine, which might explane the lack or replies.
Hopefully someone will be along for you...
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #7 on: 23 June 2012, 08:22:38 »
Drop Sam Burton a pm, he has the 2.2DTi I believe.
Not sure if he'll be able to help you :-\
AKA - Mr Bracket
markspark
  • Bolton
« Reply #8 on: 23 June 2012, 09:33:44 »
ive pm'd sam lets hope he can help it would seem it the boost problem that is causing the main issue as when i put foot down it just goes into limp  :'(
markspark
  • Bolton
« Reply #9 on: 23 June 2012, 10:13:44 »
i do have op com but to be honest im unsure how to use it  ;D i can read codes and reset/clear them and get into screen that show different values, i have just been out in the car to give it a run hoping the fault may have dried out and gone put i was wrong  :'( there is only 2 codes present now tho p1125 and p1590
