Author Topic: cutting out on cd changer?  (Read 1625 times)
rsymes2k
  • Devon
    • 99 Omega 2.5v6 CDX
« on: 23 June 2012, 08:22:59 »
Hi All,
Some reason when I flick to cd changer on my ccr600/blaupunkt cd changer and crank the volume up it cuts out? Momentarily then I turn it down and it works OK.
This is different to the radio as I can literally turn it up full blast with no issues?
Any bright ideas?
I thought it might be a dieing speaker but as its OK on the radio im not so sure?
Cheers
Rob
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: cutting out on cd changer?
« Reply #1 on: 24 June 2012, 08:19:49 »
Does it cut out with a pop or a crack?
If so, I would also suspect a speaker - I can understand your reasoning for thinking it is not as the radio is ok, but the CD tends to be a purer and higher level signal and can indeed cause this problem.
I would disconnect each speaker in turn and see if you can still get it to cut out with the CD, so that you can rule them out.
Radio & Decoding Technician
www.dndservices.co.uk
