Author Topic: Astra misfire on no 2 sparkplug  (Read 3622 times)
irratic
  • STOKE-ON-TRENT
« on: 25 June 2012, 20:25:26 »
Hi folks , really hoping for some guidance ..
Astra G . 1.4 .. Misfiring on second cylinder ... Changed coilpack and tested it on another car .. Changed plugs ... Still misfire on second cylinder ... Plug getting damp ... Turned over with coilpack out and plugs in .. No spark at no2 ... Now the only thing I can think it is is the ECM/ecu ... Dodgy tech2 read says wiring to no2 coilpack ... Any ideas ? Cheers
Re: Astra misfire on no 2 sparkplug
« Reply #1 on: 25 June 2012, 20:49:27 »
Any codes?
Compression readings?
irratic
  • STOKE-ON-TRENT
« Reply #2 on: 25 June 2012, 20:59:52 »
Can remember readings but compression was good on all 4 cylinders and prety much all the same ... Code reading was done with pedal method and that Hungarian tech 2 and both came up with the same code .... 352 I think ... Which turned out to be wiring to or from no2 coil ... No breaks in wires as checked continuity from the coil pack plug to the ecu plug ... Can another sensor kill the feed ? Egr valve faulty or something ? Cheers
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #3 on: 25 June 2012, 21:01:54 »
If that Astra has its ecu fixed to the back of the engine then yes they do play up giving the symptoms that you are having,if you try and wiggle the wiring plugs when its running it may come back to life briefly,ECUtesting.com or bbareman can sort them :y
other rides
irratic
  • STOKE-ON-TRENT
« Reply #4 on: 25 June 2012, 21:34:47 »
Thanks , I was hoping it would be something easier ... It's an old car for my son so didn't want spend too much on it .
Thanks for all your help
henryd
  • west cornwall
« Reply #5 on: 25 June 2012, 21:38:29 »
I don't think it costs a fortune to sort out,a friend had one done at a company in plymouth for around 100 notes
other rides
irratic
  • STOKE-ON-TRENT
« Reply #6 on: 26 June 2012, 17:46:08 »
another question as iv rang around for a second hand unit.. iv been told that the numbers on the ecu make no difference so long as it comes from a z14 engine with air con..??? is this correct ??
