Author Topic: MV6 3.2 rattle  (Read 3404 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: MV6 3.2 rattle
« Reply #15 on: 27 June 2012, 08:23:35 »
More than willing to have a listen  & give you my opinion if you want to pop over in it .
Probably only a couple of miles away .  Kettle is on 24/7 in this house  ;D ;D ;D
;D ;D ;D ;D ;D ;D
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
Re: MV6 3.2 rattle
« Reply #16 on: 02 July 2012, 19:22:56 »
havnt got round to changing the oil yet but was wondering what any one thought about using 15/40 semi in it ?
Re: MV6 3.2 rattle
« Reply #17 on: 02 July 2012, 19:29:55 »
I'd be dropping the Castrol shite out, putting in a better oil, and seeing what happens. Esp as this happened immediately after putting the Castrol Shite in.
My thoughts on Castrol oils are well known. Basically, I wouldn't even let it ruin my lawnmower.
Re: MV6 3.2 rattle
« Reply #18 on: 02 July 2012, 19:30:40 »
As long as the oil hasn't been changed every 20k, like the schedule suggests, history is always good.
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
Re: MV6 3.2 rattle
« Reply #19 on: 02 July 2012, 19:32:40 »
Hasn't been changed every 20k?
Re: MV6 3.2 rattle
« Reply #20 on: 02 July 2012, 19:35:29 »
How often has it been changed?
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
Re: MV6 3.2 rattle
« Reply #21 on: 02 July 2012, 19:38:25 »
Its been changed every 10k but you said "as long as it has't been changed every 20k" did you mean "has" :)
Also whats the general opinion on halfords oil and Mobils oils?
Re: MV6 3.2 rattle
« Reply #22 on: 02 July 2012, 19:44:15 »
The GM schedule is every 20k. Which is ridiculous, but pleases fleet managers.
I'd say 10k is too long.
I try to change mine every 3k ;) - the single best thing you can do :y
Given the cost of GM Semi Synth on Trade Club, no other oil is worth considering.  Its as cheap as the cheap stuff, and a very good oil. About £45 for 4 x 5l cans.
Mobil1 is another very good oil, but too expensive. I'd prefer to use a cheaper (but still good quality) oil, and change it more regularly, than an expensive oil, changed every 10k ;)
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
Re: MV6 3.2 rattle
« Reply #23 on: 02 July 2012, 19:48:36 »
so i just need someone with a TD card to get the discount on the oil then
Re: MV6 3.2 rattle
« Reply #24 on: 02 July 2012, 19:49:55 »
Yup, or join ABS for £25 a year :y
