Author Topic: MV6 3.2 rattle  (Read 3549 times)
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
MV6 3.2 rattle
« on: 26 June 2012, 18:13:20 »
Hi all,I've just done an oil change using Magnatex 10/40 and have now got a rattle,it seems to be more apparent when it's warmed up and from the bottom of the engine but it dosnt sound like a small or big end knock its deffinetly more of a rattle and goes away when the engine is revved from idle.
I'm going to do another oil change with vauxhall oil to see if it makes a difference but any info would be gratefully recieved,thanks
Re: MV6 3.2 rattle
« Reply #1 on: 26 June 2012, 18:19:01 »
very similar to mine, when hot, tapping/ticking at idle only, any amount of revs sounds fine. Its either low pressure or sticky tappet or number of tappets. (in my case it looks like a drop in oil pressure at hot idle, cold it sounds sweet)
Try GM oil as Castrol is shite, I'm tempted to try some thicker oil next change myself.
If you do stick thicker oil in, I'd be very interested to hear the results  :y
« Last Edit: 26 June 2012, 18:21:31 by tunnie »
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
Re: MV6 3.2 rattle
« Reply #2 on: 26 June 2012, 18:24:19 »
So even tho the noise is more apparent from the bottom of the engine it still points to a tappet or tappets and to the brand of oil used?
It definetly wasn't making this noise before the oil change
Re: MV6 3.2 rattle
« Reply #3 on: 26 June 2012, 18:26:47 »
Might be worth whipping the sump off to make sure the oil pick up is free from crud ;)
Re: MV6 3.2 rattle
« Reply #4 on: 26 June 2012, 18:28:16 »
If it was big end, you would really hear it. Start with fresh lot of GM oil and go from there, you could always drop the sump and check the pickup feed  :y
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
Re: MV6 3.2 rattle
« Reply #5 on: 26 June 2012, 18:37:39 »
Yeah I've had big ends and small ends go on others cars mainly rs turbos back in my younger days and they knock rather than rattle and you get a regular knock and mine dosnt do that,I'll give it a oil change and check the pick up out,other thing is its only done 65000 and has good service history if that counts for anything on these engines more than others I don't know?
Re: MV6 3.2 rattle
« Reply #6 on: 26 June 2012, 18:39:48 »
If its Vauxhall full service history, thats actually a negative  ::)
DIY service and these engines are good for 200k+  :y
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
Re: MV6 3.2 rattle
« Reply #7 on: 26 June 2012, 18:50:30 »
Na it's all independent garages,the other job I need to do is the breathers and rocker gaskets
Re: MV6 3.2 rattle
« Reply #8 on: 26 June 2012, 19:11:28 »
Is it worth running the engine with aux belt off briefly? Just in case one if the auxilarys is acting up? Might not have noticed before the oil change?
Gm oils are way cheaper than castrol, ESP on tc.
Presume it's 10/40 on the correct level?
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
Re: MV6 3.2 rattle
« Reply #9 on: 26 June 2012, 21:27:17 »
Yeah magnatex 10/40 and the level is spot on
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: MV6 3.2 rattle
« Reply #10 on: 26 June 2012, 23:29:57 »
Did you use any additives to help clean out the old engine oil before you changed it?
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
Re: MV6 3.2 rattle
« Reply #11 on: 27 June 2012, 00:12:15 »
No just drained it and changed the filter
Big_Al
Re: MV6 3.2 rattle
« Reply #12 on: 27 June 2012, 00:20:33 »
More than willing to have a listen  & give you my opinion if you want to pop over in it .
Probably only a couple of miles away .  Kettle is on 24/7 in this house  ;D ;D ;D
Halflife79
  • Southend Essex
    • 51reg 3.2 MV6
Re: MV6 3.2 rattle
« Reply #13 on: 27 June 2012, 07:36:10 »
Yeah could do thanks,I'll change the oil and see what happens and let ya know :y
Big_Al
Re: MV6 3.2 rattle
« Reply #14 on: 27 June 2012, 07:45:46 »
 :y :y
