Author Topic: Power steering issue.  (Read 949 times)
tidla
  • solihull
« on: 26 June 2012, 19:50:55 »
Had a recon power steering pump fitted which immediately restored steering assistance at idle, however its still not 100%.
It seems after a couple of dry/quick turns the assistance dissipates and you can feel the steering stiffen up.
Fitted a red relay from a breaker  which has made little impact.
Is there a filter of some description? Ran the old fluid out on tickover as there was a fair bit of metal in the system.
Any ideas?
(radio volume increases with speed so guess speed signal is ok)
Re: Power steering issue.
« Reply #1 on: 26 June 2012, 19:59:20 »
Fit a genuine used pas pump from a breaker here...?
RobseyMV6
  • west sussex
« Reply #2 on: 26 June 2012, 21:47:04 »
All the air lock out? checked bottle again, i filled many up to mark after refit and after a while bottle empty and yeah hard turning as result, top up and fine. have a few good ones here....  ::)
