CARLUBE PETROL TREATMENT Any Good or Not ?
Started by OmegaAnglesey, 26 June 2012, 21:58:48
OmegaAnglesey
I just bought one of these bottles form a local shop £3
http://www.ebay.co.uk/itm/CARLUBE-PETROL-TREATMENT-300ML-REDUCE-EMISSIONS-/250741292572?pt=UK_Car_Accessories_Car_Care_Cleaning&hash=item3a61587e1c
Has anyone used these and what do you think of them do they work at all or just a waste of money... ???
flyer 0712
I was advised by my garage to use ...cat clean to reduce the emissions and it worked very well..around £15 well spent...got it through m.o.t. :y
Personal opinion .....
If any of these "increase fuel efficiency" items ACTUALLY worked, then every motorist alive would be using them ....
Burning fuel produces energy.
To move your car requires energy
The amount you move the car is the amount of energy you use
Therefore, you have to burn the equivalent amount of fuel
Adding anything to the fuel will NOT increase the amount of energy you can get out of it, UNLESS the engine was already running poorly (rich)
The omega engine actually monitors and adjusts the amount of fuel injected into the engine by means of the lambda sensors/ecu ... it matters not what you add to the fuel .. that cycle will continue.
so IMHO .. you have wasted your money ..... IF your engine was correctly serviced. If it was NOT correctly service it is POSSIBLE that a slight cleaning effect from the additive MAY improve things slightly.
The largest contributor to your fuel consumption is your right foot ......   :)
OmegaAnglesey
Quote from: Entwood on 26 June 2012, 22:07:22
True, I dont know why i bought it TBH but you see these things in the shops you think you want and when you get home you think why did i buy that  ;D  ... I probable will just put a bit at a time in as i never fill the tank to 50L as the bottle of that stuff says to do.
waspy
About the only thing that works off the shelf is diesel injector cleaner. Use it when you change the filter.
Forte petrol fuel treatment as an annual clean seems to help, particularly is using cheap supermarket fuel regularly
tgm147
Another vote for Forte Petrol Fuel Treatment here. Actually felt a proper difference after using it on another car.
tigers_gonads
Quote from: tgm147 on 28 June 2012, 11:37:26
Good stuff  :y
Does a great job of stripping the laquar build up on the injectors  :y
I tend to stick a can in once or twice a year  ;)
Used various different bits and I'm 99% sure they do absolutely naff all. Agree with Entwood totally. Forte is supposed to be the best, however, it's never done nothing for me. Used Redex in something all that happened was it ran like shit after.
Found regular use (1 - 2 x per annum) of Wynns Injector Cleaner works well. :y
I used to use Forte in my petrol cars about once every 18 months or so.  As I only have LPG cars now, they get no treatment.
Diesels can certainly benefit, esp as supermarket diesel is pretty poor.
