Is Wynns Lifter Treatment any good?
Started by Webby the Bear, 28 June 2012, 18:32:02
Webby the Bear
As above...
I have heard mixed reviews about this and know it hasn't helped the Tunnster.... has it helped anyone else though?
RIP Paul Lovejoy
Works for some, I hear.......but not for all. Lottery. ;)
Webby the Bear
yeah I've heard that. I suppose giving it a go and seeing. I take it no harm can be done to the engine?
RIP Paul Lovejoy
My issue is more pressure related than lifter, it does work rather well if a sticky lifter is your problem.
No harm sticking it in  :y
It works very well. Used it several times with good results in that it quitens down the top end tap you get from too long an oil change interval.
It is lifter treatment. Very specific product. The fact it hasn't worked on Tunnies car means the problem is not to do with goop blocking the lifter oil ways. So the logic is, his issue lies elsewhere, not that wynns LT doesn't work. If that makes sense...?
I agree, it works if thats the problem.
Works best by changing the oil, then putting it in and leaving in for 3k miles.
henryd
Quote from: chrisgixer on 28 June 2012, 19:43:11
Agreed,I've had good results using it in the past :y
other rides
the alarming man
Manual Elite V6
I have used this many times with good results, also recommended it to a few friends who also had good results.  :y
1992 Cavalier GSi
2007 Astra Sri+ CDTi 150
Webby the Bear
i note that a bottle does cars that take up to 6L of oil. perfect.... however, when i do my oil change should i still put 5.75L in or reduce the oil to take into consideration the lifter treatment? :)
RIP Paul Lovejoy
Manual Elite V6
Just put in the normal amount of oil, the treatment won'e make much difference to the level, thats how I have always done it anyway.
1992 Cavalier GSi
SteveAvfc.
sassanach
lifter treatment or atf, same effect,except of course that atf is cheaper!!
