Author Topic: strange noise, shot wheel bearing or...?  (Read 3322 times)
mathewst
  • Split, Croatia
    • v40
« on: 28 June 2012, 21:35:59 »
Noticed strange noise comming from the back of the car this morning.
Noise appears only when driving faster (over 70 75 kph) and noise isn't constant)
It is like something is noticeably banging onto something else.
It isn't to loud but it definitely is there.
Also seems the bumps and corners affect it (can be heard more often on bumps and twists).
Exhaust seems to be in its place so I don't think it is it.
Can this be rear wheel bearing, shock or something else?
Re: strange noise, shot wheel bearing or...?
« Reply #1 on: 28 June 2012, 21:56:05 »
Bearing = rumble?
Shock mount = knocking?
SL shock = banging over bumps?
jibberwobble
  • swindon
    • 3.0 MV6 Estate 2000 W
« Reply #2 on: 28 June 2012, 22:06:19 »
In my experience rear wheel bearings make a constant moan/rummble in a straight line, get louder when loaded (right bearing in a left hand corner) and quieter when unloaded (corner the other way or cresting a hump back bridge).
I have one on the way out now and its been doing since I bought the car four months ago without getting much worse. I still cant feel play in the wheel either or I'd have changed it by now. My last omega was exactly the same and drove on it for about 6 months still not feeling any play in the wheel but in the end changed it because it was getting on my boobs.
Not a nice job! think the garage may have to do this one as I'm feeling lazy.
mathewst
  • Split, Croatia
    • v40
« Reply #3 on: 28 June 2012, 22:15:26 »
It is not rumble nor knocking
Best described is something like huming with some slight kocking,
Seems to be more loud if rear seats are ocupied
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #4 on: 28 June 2012, 22:27:19 »
check your mud flaps arnt lose. or any other plastics at back are not lose and shock damper at the top of shock.
« Last Edit: 28 June 2012, 22:31:04 by freecall666 »
Solar charger fitted.
If not Broke dont fix it..
mathewst
  • Split, Croatia
    • v40
« Reply #5 on: 28 June 2012, 22:35:53 »
no mud flaps
Shock damper? this is I guess rubber cup n top of the shocks?
Are these even visible? or I must jack the car up
freecall666
« Reply #6 on: 28 June 2012, 22:38:53 »
no mud flaps
can see them in boot no need to jackup think on new mods they have a cover over them.. next to wheel arch top
mathewst
  • Split, Croatia
    • v40
« Reply #7 on: 28 June 2012, 22:41:10 »
Aha ok I see what you mean but cannot see how these cups could make this kind of noise.
Thanks for the idea though  :y
freecall666
« Reply #8 on: 28 June 2012, 22:43:48 »
changed mine as the rubber had split and shock was rattleing in the hole, changed the rubber and its stopped.
got to the end and just banged ever tiny bump in road. was just intermitant rumble.
« Last Edit: 28 June 2012, 22:45:41 by freecall666 »
mathewst
  • Split, Croatia
    • v40
« Reply #9 on: 28 June 2012, 22:45:11 »
OK will check tomorrow,
thanks
