Author Topic: Heater Matrix  (Read 1996 times)
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
Heater Matrix
« on: 29 June 2012, 17:51:13 »
     Do we have a How To on removing the above, if we have would someone please give me a push in the right direction, :y I'm sure I read one where it's removed from the side, by the drivers feet but I can't find it,  :'( :'(
Regards
    Dave
DaveA
  • Leicestershire
Re: Heater Matrix
« Reply #2 on: 29 June 2012, 18:26:07 »
Thanks Rob   :y
Regards
    Dave
amba
  • Medway towns
    • German V6
Re: Heater Matrix
« Reply #3 on: 29 June 2012, 22:38:10 »
Not such a bad job really,but dont cut away anymore of the trim/dash than is necessary as that way you will end up with an almost invisible repair.
The 2 rubber "0" rings from VX are silly money but unsure if much else would work..matrix can be bought new for around £40 so also not too expensive a repair either.
Better to be doing this in the warmer months ...I ended up changing mine in early February and it was bloody cold especially using the car for the 3 days whilst I waited for the new matrix to be delivered.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Heater Matrix
« Reply #4 on: 30 June 2012, 10:05:22 »
why do you have to chop car up to get at matrix :-\
Re: Heater Matrix
« Reply #5 on: 30 June 2012, 10:12:11 »
Around £18. Heat exchanger (matrix) Same across the range http://www.buypartsby.co.uk/buy/VAUXHALL/OMEGA/2.2/2002/__/68/cooling-heating/cooling-heating/radiators/
Re: Heater Matrix
« Reply #6 on: 30 June 2012, 10:12:33 »
Read the guide ;)
amba
  • Medway towns
    • German V6
Re: Heater Matrix
« Reply #7 on: 30 June 2012, 10:28:49 »
Crickey,Rob...thats cheap.
I bought mine from local factors ..is a Nissenn and was £41.28 inc so I was happy to pay that just to get some heat  ;D
Did find that the aftermarket type don,t have the foam wadding around the ends so you end up with quite a loose fit in the craddle and get cold air blasting through.I rolled up some thin foam and packed it around the edge of the matrix and job sorted.
DaveA
  • Leicestershire
Re: Heater Matrix
« Reply #8 on: 30 June 2012, 12:46:45 »
    Can I recap?
                I'm loosing cooling water slowly, the condense water from under the motor tastes bitter, although it's gin clear, does this indicates that a new Heater Matrix is required??
                Lacking a bit of confidence at the moment. :-[  Little push required :y :y Before I start cutting.
Regards
    Dave
Re: Heater Matrix
« Reply #9 on: 30 June 2012, 12:49:02 »
If matrix is leaking, interior front carpetting (mainly driver`s side) will be damp/wet. You sure it`s not the HBV
amba
  • Medway towns
    • German V6
Re: Heater Matrix
« Reply #10 on: 30 June 2012, 16:19:43 »
Doesn,t sound like you have a problem with your heater matrix.
As advised you will know if it lets go as drivers footwell and behind seat area will get a very wet carpet.Quick check would be to start car and put heater on Hi..put hand down into drivers foot well and feel carpet if its leaking you will know pretty quickly.
Sounds more like HBV or associated pipework if you are only loosing a bit but needs looking at.....Dont start cutting the dash though ;)
DaveA
  • Leicestershire
Re: Heater Matrix
« Reply #11 on: 01 July 2012, 08:43:27 »
Thanks Rob/amba
                 Bone dry in foot wells.  Cann't see any leaks anywhere, no coolant stains either, will change HBV anyway, if it isn't that, Ill class it as preventive maintenance 8) :y
Regards
    Dave
