Author Topic: wheel bolt stripped  (Read 2668 times)
bigegg
  • Leeds
    • MV6 RIP - Lexus GS300 '99
wheel bolt stripped
« on: 29 June 2012, 23:30:23 »
further to my "MOT again" thread in general car chat -
car has failed on "missing wheel bolt" on rear o/s
Trouble is, the hole in the hub(?) has stripped so I can't just replace the bolt.
I don't even know what the part is called - is it the hub?
How difficult to replace? - is it as much work as changing the wheel bearing?
Would I be better filling the hole with weld, then drilling and re-tapping? what size thread?
Are helicoils still available?
Or should I just blu-tack the bolt in for the MOT?  :-X
Carpe Incendium
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: wheel bolt stripped
« Reply #1 on: 29 June 2012, 23:36:01 »
you used to be able to use a crimp in old days when there used to be just 4 holes for holding the wheel on but dont know if they are legal any more? was a bit like a helicoild did the same job.
Solar charger fitted.
If not Broke dont fix it..
  • Auckland
    • Mazda MPV
« Reply #2 on: 30 June 2012, 11:00:08 »
To change the rear hub & half shaft you need to
- unbolt the 6? bolts holding the drive shaft to the drive flange
- undo the big nut holding the drive flange on
- take off the wheel, brake caliper & brake disk
- pull off the drive flange
- pull the rear hub & half shaft out of the wheel bearing.
- press in a good used hub & half shaft and put it all back together again  :y
bigegg
  • Leeds
« Reply #3 on: 30 June 2012, 11:26:14 »
so easier than changing a bearing then?
I think I'll make it easier still, and take the wheel of first, instead of third.   :D
ta very much
Carpe Incendium
  • Auckland
    • Mazda MPV
« Reply #4 on: 30 June 2012, 11:36:17 »
You have to take the the half shaft out to get to the wheel bearing. If you are up for a challenge you could do the wheel bearing as well ;D
To undo the big nut on the back of the drive flange you need to stop the shaft from turning. Leaving the wheel on is the easiest way to stop it turning.
bigegg
  • Leeds
« Reply #5 on: 30 June 2012, 14:19:58 »
wheel bearing done last november :-[
<off to parts wanted>
Carpe Incendium
  • Auckland
    • Mazda MPV
« Reply #6 on: 30 June 2012, 14:26:45 »
On a positive note....... if it was taken apart 6 months ago it should come apart relatively easily now :y (assuming no bodgery happened last time  ::))
sassanach
  • trowbridge
« Reply #7 on: 30 June 2012, 14:39:17 »
do yourself a big, big favour and just helicoil it :y
  • Auckland
    • Mazda MPV
« Reply #8 on: 30 June 2012, 14:55:38 »
Do you feel lucky?
What caused the original thread to strip? My money is on a gorilla with a windy gun reaming all of the wheel bolts up to some unknown torque. >:( If this one has gone the other 4 may be damaged also :o
The MOT doesn't require removal of the wheels so a helicoil would gain a pass certificate but I would certainly have a good look at the condition of all the wheel hubs (and would sleep easier if this one was swapped)
sassanach
  • trowbridge
« Reply #9 on: 30 June 2012, 20:19:18 »
do i feel lucky?...no i have dismantled several rear wheel brg's and i only got lucky once,every other time the wheel brg was destroyed on removing the stub axle.still its your call.
bigegg
  • Leeds
« Reply #10 on: 30 June 2012, 20:55:02 »
I'm gonna go with the blue tack, then.  :y
Carpe Incendium
