Author Topic: Live Data Reading: Parameters  (Read 1076 times)
PLANETNZ
  • Christchurch New Zealand
    • 2000 CD 2.5 x25xe 80000km
« on: 01 July 2012, 00:33:02 »
Can someone post a set of live data parameters of what range(s) everything should be in?   My car seems to be running a bit rich and ive done a couple of readings, im just trying to get an idea of what values everything should be in??  cheers
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Live Data Reading: Parameters
« Reply #1 on: 01 July 2012, 01:52:23 »
what engine size is it that you want live data from?
Solar charger fitted.
If not Broke dont fix it..
PLANETNZ
« Reply #2 on: 01 July 2012, 02:46:52 »
2000 2.5 just want some parameters to compare my readings with. i dont have any codes but it seems to be running a bit rich although is running better than ever! :)
« Reply #3 on: 01 July 2012, 09:30:36 »
Once it goes closed loop, check that B1S1 and B2S1 flick between Rich and Lean about once a second.
