corsa sxi 1.2help please
Started by r1, 01 July 2012, 18:22:34
r1
my mrs corsa b 1.2 sxi engine is leaking oil from the top of the engine so after a look round i have decided its the rocker cover gasket.
now it looks a "simple job" to do but as i havnt a manual any tips would help.now the cover is held on with some strange bolts[tork? about 10mil] so of to buy some  sockets tomorrow
does anyone know if they have to be loosened off in a special way? or if there is a torque setting for these?
thanks
sticka_v8_init
Those are my principles, if you don't like them I have others.
Brikhead
Quote from: r1 on 01 July 2012, 18:22:34
thanks
Make sure the oil isn't coming from the oil pressure switch, located up near the thermostat and timing chain cover.
Quote from: sticka_v8_init on 01 July 2012, 23:00:03
- not too sure about the "screw driver tight bit"  tho :-\
Nah, it's good advice as the bolts only go into aluminium and it's easy to strip the threads. I'd guess 8-10 n.m.'s at most.
r1
[/quote]
good point about the oil switch
thanks
