Author Topic: 2.5TD, leaking fuel at injector.  (Read 3490 times)
Agemo
  • Cleethorpes
  • Insignia
« on: 03 July 2012, 15:38:28 »
As above, No 6 injector leaking somewhere at the bottom, tried nipping it up but no different. Rang dealers to see if they had seals, but apparently none listed so they don't need them (anyone remember if they do?) I do have a spare set, so after work tomorrow, I will try replacement of one/all injectors. Not sure why an injector would start leaking. Any thoughts?   ::)
bootie
  • Enix, Almeria, Spain
Re: 2.5TD, leaking fuel at injector.
« Reply #1 on: 03 July 2012, 16:40:10 »
Sure it's the injector and not the leak off pipe?
« Reply #2 on: 03 July 2012, 17:07:24 »
There is a copper washer at the bottom. Re-aneal it.
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 03 July 2012, 21:33:32 »
All leak-off pipes are new & not leaking. I thought there was a copper washer of some sort, thanks TB.
Cherry red then quench in water?
« Reply #4 on: 03 July 2012, 21:35:47 »
I thought naturally cool?
« Reply #5 on: 03 July 2012, 21:37:01 »
Dull red .. don't overcook .. then either quench or cool naturally .. for non-ferrous it makes no difference.. ferrous MUST be cooled naturally
EDIT
For those who doubt ....
http://en.wikipedia.org/wiki/Annealing_%28metallurgy%29
Second paragraph .. :)
« Last Edit: 03 July 2012, 21:38:50 by Entwood »
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 03 July 2012, 22:15:54 »
OK, thanks, we all learn on here.  :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #7 on: 03 July 2012, 23:13:02 »
Injector-to-head torque setting is 65 Nm ;)
Agemo
  • Cleethorpes
  • Insignia
« Reply #8 on: 04 July 2012, 21:39:49 »
Thanks for that Byron, not got to that stage yet. I forgot what a pita the inlet manifold was. Anyway, No 6 injector out, no sign of damage, (although a little sooty), copper washer annealed, ready to fit spare injector. Got caught in a couple of downpours, taking usual medication (Whiskey).
Agemo
  • Cleethorpes
  • Insignia
« Reply #9 on: 05 July 2012, 16:39:37 »
Job done, thank to all for the advice. I also need to replace a leak-off pipe, perhaps I caught it with the manifold, or it is past it's best. (one whole year!!!)
Page created in 0.021 seconds with 16 queries.
