Author Topic: problems!!  (Read 2812 times)
horsecow
  • Omagh
    • 2.2 dti cdx/3.2 elite
problems!!
« on: 03 July 2012, 16:33:24 »
Hi all, was doing nothing today so decided to monkey about with the motor. Took crankcase breather off and gave all a good clean then decided to have a look at the coilpacks when I was at it. This is where the problems started.
1.  Whoever took the 1,3,5 coilpack off last had wrung one of the bolts and not bothered fixing it, just pushed it back in!!! Now I'm guessing this is gonna be a bitch to fix so I need all the help you can give me.
2. On removing 2,4,6 coilpack i noticed a lot of dust/dirt caked inside around the plugs. The seals on the coilpack look ok but overall its looking a bit tired so will be replaced as soon as possible. Just wondering the best way to get a good clean in there as it looks very small and tight inside. Will obviously replace the plugs as well.
3. Have got 2 prices for the new coilpacks, £140 from vauxhall dealer or £67 from local parts store. Local guy says its a geniune brand but Ive forgotten the make of it, anyone think the cheaper one would be ok??
Drive 'er like yer late for mass!!
Re: problems!!
« Reply #1 on: 03 July 2012, 16:38:18 »
1. Does the other bolt bite & hold? If so i'd say just live with it, just check it every oil change  :y
2. I would not worry too much about dust/dirt, just do what you are doing and remove it every so often and clean it.
3. Ring AndyC, he will give you trade price of the coil pack for a lot less that £140.
Re: problems!!
« Reply #2 on: 03 July 2012, 17:06:41 »
I used a Bosch coilpack, about £80 iirc.  There was a no-name one about £10 cheaper at the time...
horsecow
  • Omagh
Re: problems!!
« Reply #3 on: 03 July 2012, 17:33:58 »
Yeah the other bolt is holding fine so I guess i'll just leave it then. How do I get a number for andy c tunnie?
Re: problems!!
« Reply #4 on: 03 July 2012, 17:35:04 »
PM him ;)
Or I think his signature has his phone number on.
Re: problems!!
« Reply #5 on: 03 July 2012, 17:40:08 »
http://www.omegaowners.com/forum/index.php?topic=97927.msg1307435#new
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: problems!!
« Reply #6 on: 03 July 2012, 17:57:53 »
Has the coilpack actually failed? If not is there any point replacing?
RIP Paul Lovejoy
horsecow
  • Omagh
Re: problems!!
« Reply #7 on: 03 July 2012, 18:02:34 »
The pedal trick is telling me that there's a misfire on 2,4,6 so I guess thats down to the coilpack and the dirt/dust thats in there or the plugs so changing both just to be sure.
Webby the Bear
  • Northampton
Re: problems!!
« Reply #8 on: 03 July 2012, 18:15:44 »
ok, that makes sense  :y however, i'd get clarification from somebody on here that it's definitely nackered as my understanding is the pedal trick shows old codes that may not be a problem anymore. just trying to think of your wallet  :y
RIP Paul Lovejoy
hercules
  • sunnyudders
Re: problems!!
« Reply #9 on: 03 July 2012, 18:22:52 »
omega and wallet  ;D go together like a wife and your credit card  ;D
Webby the Bear
  • Northampton
Re: problems!!
« Reply #10 on: 03 July 2012, 18:44:35 »
 ;D
Tell me about it. Wheel Alignment done today (very nice chap at WIM). I watched the whole thing. great to see. is it the tie rods they adjust when adjusting wheel alignmemnt?
Anyway, i got to have 4 new tyres soon, wheel balancing, front pads n discs, oil change, lifter treatment......... the point is the expenditure never ends  :'(
RIP Paul Lovejoy
Re: problems!!
« Reply #11 on: 03 July 2012, 19:10:17 »
 ;D
All adds up dont it , at least you can save £1000's in garage bills
