Author Topic: Cam Kits  (Read 2878 times)
mhwest
Cam Kits
« on: 03 July 2012, 20:24:08 »
HI lads
 Looking for Cam belt kit and water pumps that are not Vauxhall make, a bit pricey  even with vauxhall club card so looking for a reliable make to replace them, there seems quite a few makes on the market any news would help thanks ;)
Re: Cam Kits
« Reply #1 on: 03 July 2012, 20:49:04 »
Contitech or Gates will be quality kits with SKF bearings, and a lot cheaper
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: Cam Kits
« Reply #2 on: 03 July 2012, 21:02:39 »
never tried contitech but have a gates fitted to mine :y
mhwest
Re: Cam Kits
« Reply #3 on: 03 July 2012, 22:05:06 »
Thanks will buy at a later date but soon have bought timing tool and other bits all add up, belt is priority as no info when last done  :y
noel
  • frome somerset
Re: Cam Kits
« Reply #4 on: 03 July 2012, 22:28:14 »
make sure tensioners are replaced as well as it is them that seem to fail, some members also change water pump at same time (just to be safe ) :y
Re: Cam Kits
« Reply #5 on: 04 July 2012, 01:59:56 »
Contitech kits good - get from Buypartsby
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Cam Kits
« Reply #6 on: 04 July 2012, 07:35:59 »
 got mine from herehttp://www.autovaux.co.uk/LoadPortal.aspx?tabid=2 :y
  OE spec kit and nice people to deal with :y
« Last Edit: 04 July 2012, 07:40:36 by biggriffin »
Hoof'land storeman.
jonathanh
  • coventry
Re: Cam Kits
« Reply #7 on: 04 July 2012, 16:59:06 »
4 pot then essential to look at the waterpump as a failure there throws the belt off.  For normal size engines it is not essential - WP is aux belt driven
mhwest
Re: Cam Kits
« Reply #8 on: 04 July 2012, 21:07:08 »
Did a cam belt change a number of years ago on a 2.5 CDX, ring spanner was a straight one so could do with a crank one for ease but not sure which one it was , it is the one that fits the guide roller adjusters so need size before starting job, the car is also a 2.5 facelift model
Re: Cam Kits
« Reply #9 on: 04 July 2012, 21:47:03 »
30mm cranke ring spanner ;)
flyer 0712
Re: Cam Kits
« Reply #10 on: 04 July 2012, 22:04:46 »
As said...i always replace..belt..tensioner  ...water pump on my 2.2 to be safe  :y
mhwest
Re: Cam Kits
« Reply #11 on: 04 July 2012, 22:53:29 »
Thanks again I will use full kit and new water pump spanner was the issue as I have a number of large ring ones but could not remember which one it was,it was at the time not ideal so will buy another with a good crank on it :ywill have a go in a couple of weeks garage seems a bit tighter must be the facelift bumpers ???
