Author Topic: Exhaust Phew  (Read 4362 times)
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
Exhaust Phew
« on: 07 July 2012, 17:52:14 »
   Am loosing water, can sometimes a bit lumpy on start up, now the exhaust as a pleasant sweet smell when I start first time, no rotten egg smell. Am I right in thinking head gasket needs replacing. No warning lights.   Car runs well normally?
« Last Edit: 07 July 2012, 17:54:42 by DaveA »
Regards
    Dave
jonathanh
  • coventry
Re: Exhaust Phew
« Reply #1 on: 07 July 2012, 20:17:21 »
No.
No reason to suspect hg. Need methodical diagnosis.
Re: Exhaust Phew
« Reply #2 on: 07 July 2012, 20:26:44 »
What makes you think head gasket gone? ???
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
Re: Exhaust Phew
« Reply #3 on: 07 July 2012, 22:26:16 »
my guess is that antifreeze smells sweet......     (thus it's use in austrian wine) and the OP, smelling that sweetness in his exhaust has concluded that there's coolant getting in to the system somewhere, and being shoved down the exhaust....
it's not impossible.....  but i'd expect it to be over pressurising the coolant system,
you losing coolant at all ???
the only place i've seen v6 HG's go is passenger bank rear left nearside corner .....  seen 2 or 3 personally ,  and heard of several others....   and only on late 3.0 v6,   not personally seen one on 3.2 or 2.6, but it doesn't mean it's impossible.....  however, it usually manifests in a slight coolant leak at the rear of the block on the near side....
too often i've heard the phrase "they never go" about assorted bits on our migs....    and it turns out to be the exception again.....    so these days i assume that it could be....  even if it's unlikely.....
Re: Exhaust Phew
« Reply #4 on: 07 July 2012, 22:32:00 »
Looks like OP drives a 2.2 four pot. Head gasket problem much more likely on a four pot. ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Exhaust Phew
« Reply #5 on: 07 July 2012, 23:07:58 »
have to agree with albitz  2.2 and head gaskets yup  :y
Hoof'land storeman.
MaxV6
  • Oxford UK
Re: Exhaust Phew
« Reply #6 on: 08 July 2012, 00:14:35 »
oops , should have noticed......    :-X
DaveA
  • Leicestershire
Re: Exhaust Phew
« Reply #7 on: 08 July 2012, 09:37:04 »
Thanks for replys
                       Yes I drive a 2.2. If the cooling system is being over pressurised, would a new expansion tank filler cap cure it.    Mark DTM did a diagnostic about a fortnight ago every thing seemed ok then.  Think I will let a local garage, that Mark recommended, have a look :-\
Regards
    Dave
DaveA
  • Leicestershire
Re: Exhaust Phew
« Reply #8 on: 09 July 2012, 08:40:55 »
   I have checked all the coolant hoses and hose connections, replaced HBV, still loosing coolant, going to replace head gasket. Anyone any other ideas?   Going to VX for gaskets. What about replacement head bolts and camshaft sprocket bolts, is it best to stay with VX or will sets from ebay suit?    2.2 model.
« Last Edit: 09 July 2012, 08:42:45 by DaveA »
Regards
    Dave
Re: Exhaust Phew
« Reply #9 on: 09 July 2012, 09:48:31 »
Awaits reply from RobG.
If the spark plug is removed after a lay up, any water in pot 4 sitting on the piston? Any water in the oil?
DaveA
  • Leicestershire
Re: Exhaust Phew
« Reply #10 on: 09 July 2012, 12:35:05 »
      Tried that, but could not see well enough to tell one way or another.  If I leave car standing for a while, release all pressure form the expansion tank, then start engine tank pressurised very quickly well before water is hot. No water in oil, or oil in water, well not that I can see.Just  been down to a garage (not VX) and HG is his opinion. Am loosing a lot of water now, have to top up after 30 - 40 miles, but only when car running, not when car is standing, cannot see any leaks, no water on the floor either.
      Thing is off to Dorset a week Wednesday, if there is likely to be any other cause, we've haven't much time.
    PS
 One thing I found to the good, was that I have had a rattle for a long while, that I could no find. When checking to see if radiator drain tap was leaking, noticed the the twin horns were rubbing together, bent brackets a bit, no rattle :y
« Last Edit: 09 July 2012, 12:41:43 by DaveA »
Regards
    Dave
Re: Exhaust Phew
« Reply #11 on: 09 July 2012, 12:43:47 »
Get your hands on a compression tester and check each cylinder.
174-218 psi (12-15 bar)
Allowable difference between cylinders = 15 psi (1 bar)
Re: Exhaust Phew
« Reply #12 on: 09 July 2012, 12:44:32 »
If the header tank pressurises instantly, there is only one place that pressure can come from, IMHO. Through the head gasket.
Lumpy running from start-up is also a symptom, as is coolant smell from the exhaust.
How many miles has it done? Not at all unusual for a 2.2 with 6 figure mileage. :-\
DaveA
  • Leicestershire
Re: Exhaust Phew
« Reply #13 on: 09 July 2012, 13:38:22 »
     Motor has covered just under 97,800 been Tesco's shopping and instead of the water expanding in the tank it looked like the water was being pushed down.
Regards
    Dave
DaveA
  • Leicestershire
Re: Exhaust Phew
« Reply #14 on: 09 July 2012, 13:46:27 »
  Did a test, only a cheep tester though, that showed evenly on all four pots, so I change the HBV which had not shown any leaks. Still using a lot of water and getting worse.
Regards
    Dave
