Author Topic: My Pain in the A**  (Read 2713 times)
babes99
My Pain in the A**
« on: 07 July 2012, 18:38:57 »
Ok have been having stalling issues for sometime now, 1999 omega, 2ltr 16v CDX A
Today was the worse day normally it will stall and then restart and run fine till the next time. Today however Stalled 11 times coming out of a multi car park twice on the down ramp. Then the Auto gearbox went. Normally fuse number 9 but it is fine. Then stalled everytime i took my foot off the throttle, till the battery died! Now parked up awaiting tow. Any ideas ?
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
Re: My Pain in the A**
« Reply #1 on: 07 July 2012, 18:56:46 »
any lights on (eml/spanner etc) or errors on the display ?
can you get the codes read, or do the paperclip or pedal trick http://www.omegaowners.com/forum/index.php?topic=90581.0 if yours will do that
babes99
« Reply #2 on: 07 July 2012, 18:58:50 »
The lights come on just before it stall's, I will get the fault codes read in a couple of days it is running a river outside today.
babes99
« Reply #3 on: 07 July 2012, 19:01:48 »
The only display message was the auto gearbox when it went into limp mode, I also get a coolant warning but have had that for nearly two years
waspy
« Reply #4 on: 07 July 2012, 19:07:15 »
Could be something as simple as a fuel filter change.
« Reply #5 on: 07 July 2012, 19:07:53 »
Cleaned ICV?
babes99
« Reply #6 on: 07 July 2012, 19:14:10 »
what is ICV?
babes99
« Reply #7 on: 07 July 2012, 19:15:22 »
I will keep this in mind, Bloody car is doing my head in now... Anyone got swan vista's  ;D ;D
babes99
« Reply #9 on: 07 July 2012, 19:28:43 »
what is ICV?
Idle Control Valve, see here: http://www.omegaowners.com/forum/index.php?topic=90633.0
Guide here:
http://www.omegaowners.com/forum/index.php?topic=90586.0
Thanks my Hubby will start that tomorrow, Hope that fixes the problem if not scrap heap here we come.
« Reply #10 on: 07 July 2012, 23:04:31 »
Stalling and re starting, was the cam or crank sensor? :-[ that was faulty on ours, get the codes read as on the 2.0L engine the car can still run with these faulty..... :)
Page created in 0.238 seconds with 20 queries.
