Author Topic: Poor MPG  (Read 1896 times)
apcollis
  • London
    • 2002 Omega 2.2 petrol
Poor MPG
« on: 07 July 2012, 21:49:49 »
Hi Everyone
I have just bought my third Omega but this is the first 2.2 petrol.
I am currently getting 14.6 mpg which seems a bit harsh, the car also has a misfire on first start up if I dont just drive away, if I drive away it doesnt misfire. Can anyone offer any advice?
All the best
Andrew
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
Re: Poor MPG
« Reply #1 on: 07 July 2012, 22:50:20 »
Obvious one is to check plug wells for oil or water. leaky cam cover gasket or widscreen scuttle
Check coil pack while you at it for arcing etc while your at it.
Next thing is breather pipes and ICV (idle control valve) and then maybe throttle body
look in maintenance guides for instructions
MPG can seem bad if you have just reset it and not had a run but some of the above will help with MPG. The 6 pot owners on here will tell you you have 2 less than required  ::)
HTH Phil
By the way put the info of your car in your profile (see mine <---)  so people know what they are talking about
« Last Edit: 07 July 2012, 22:55:02 by Philbutt »
Victor Meldrew
  • Bangor, County Down
    • 2002 2.2 CD Auto Saloon
Re: Poor MPG
« Reply #2 on: 07 July 2012, 22:55:53 »
Hi apcollis,
My 2.2 petrol can show 18 MPG on a short stop/start jaunt  :'( but give over 40 MPG on a long motorway journey.  :y Average over a tankful is 30 MPG. So with 14.6 MPG I think something is amiss.  Misfire might suggest oil in spark plugs, is the cam cover gasket leaking? Common problem, I'm about to change mine as it's leaking at the back after only 4 months.  A pattern gasket was fitted by a local garage in March. I'm fitting a genuine GM gasket and would suggest you do the same if you find this is the cause of your misfire.
HTH
"A normal man in a world full of idiots"
Re: Poor MPG
« Reply #3 on: 07 July 2012, 23:01:42 »
HTH Phil
Not on a DBW Phil ;)
SIR Philbutt
    • PJB Home Services
Re: Poor MPG
« Reply #4 on: 07 July 2012, 23:31:01 »
HTH Phil
Thanks for that Rob wont make that mistake again  :-[ . Not an expert just trying to help, he would have found out anyway  ::)
What does DBW stand for  ???
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: Poor MPG
« Reply #5 on: 08 July 2012, 08:12:37 »
HTH Phil
drive by wire  (non cabled accelerator) :y
apcollis
  • London
Re: Poor MPG
« Reply #6 on: 09 July 2012, 02:03:05 »
Hi everyone, thanks for your replies, its very much appreciated. So far I disconnected the maf sensor and started it which made the misfire better, not sure if I'm going in the right direction or coincidence, I will look at all your ideas tomorrow. Serious bout of man flu has kept me away from the car for the weekend but have to grow up to go to work tomorrow so will check at lunch time. The car is a 2002 2.2 petrol but I will update my profile in a sec. Thanks again everyone so far.
