Author Topic: valve stem seals  (Read 2721 times)
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
valve stem seals
« on: 09 July 2012, 20:15:07 »
been getting a puff of smoke form exhaust on start up for about 2 seconds then followed by a click sound then all is fine . Believe this could be valve stem seals :-\. Unless anyone has any other suggestions ;)
Does anybody have any advice on stem seal replacement (can this be done without removing heads ??)
Thanks Noel :y
Re: valve stem seals
« Reply #1 on: 09 July 2012, 20:47:10 »
Thanks Noel :y
Yep, special tools needed
noel
  • frome somerset
« Reply #2 on: 09 July 2012, 21:03:01 »
Thanks Noel :y
would the tools be these by any chance  :-\    http://www.ebay.co.uk/itm/Valve-Seal-Removal-and-Installer-Stem-Plier-Tool-Set-Kit-Professional-in-Case-/120934620808?pt=UK_Hand_Tools_Equipment&hash=item1c2843de88
« Last Edit: 09 July 2012, 21:04:59 by noel »
Abiton
« Reply #3 on: 09 July 2012, 22:08:36 »
There's a bit more to it than that.
First you've got to have a method for keeping the valves closed while compressing the valve springs.  This could be compressed air through a special adaptor into the spark plug holes, or more 'ghetto'; rope fed into the cylinder down same hole with piston low, and then the piston moved up 'til it will go no further against the rope.
Then you need a tool that will push each top spring retainer downward far enough to get the valve collets off the stem, releasing the top retainer, giving access to the seal.  If you're a bit handy you may be able to lash up some sort of lever system DIY.
Not a quick and easy job by any means.
noel
  • frome somerset
« Reply #4 on: 09 July 2012, 22:22:57 »
thanks for the replies guys :y  may let it smoke for a bit then and see what happens  ;)
serek
  • huntingdon
    • 3.2 mv6
« Reply #5 on: 09 July 2012, 22:48:22 »
always can try this, but this tool work with air compressor
http://www.ebay.co.uk/itm/VALVE-SPRING-COMPRESSOR-TOOL-KIT-VALVE-STEM-OIL-SEAL-TOOL-SOHC-DOHC-/360404129679?pt=UK_Recovery_Tools&hash=item53e9c2978f
noel
  • frome somerset
« Reply #6 on: 09 July 2012, 23:00:37 »
thanks for the link serek  :y   that looks an interesting bit of kit :)
cleggy
« Reply #7 on: 10 July 2012, 08:05:42 »
Mines been merrily doing it for 3 years  ;) IIRC Vauxhall say it is not a problem unless you start using more than 1litre of oil per 1000 mile. :y
noel
  • frome somerset
« Reply #8 on: 10 July 2012, 19:14:44 »
Had thought about trying Forte seal conditioner to see if that helps :-\, but im sure someone will be along who has tried some maybe ;)
martin42
« Reply #9 on: 10 July 2012, 20:05:36 »
I've used stp oil treatment in the past,had an astra mk1 van that loved oil,chucked a tin of that in and it cut it down by 90% easily  :y
noel
  • frome somerset
« Reply #10 on: 10 July 2012, 21:09:26 »
think i will give it a go nothing to lose ;)
