Author Topic: Oil lack warning arter engine swap  (Read 1234 times)
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« on: 10 July 2012, 13:35:36 »
I just changed the engine in my Opel omega mv6 due too cambeltfailure. Car and old engine is 95. The new engine came from a 95 manual but im told it once came out of a 99 omega. Both engines Are x30xe. Had to swap most of the wiring over from the old engine to Get the right connectors for my autobox. Also used most of the sensors from the old engine because they had square connectors and the oval ones from the new engine didnt fit the wiring loom. The only bit of wiring i kept of the original wiring on the 99 engine is the bit around the starter, generator and oil sensor. Amazingly the new engine fired right up with no issues egen installed in the car. Only problem i cant figure out is the mid keeps saying oil lack. With the old engine it used to say old level, and the change to oil lack if i ignored the first Message. Are both warnings generated from the same sensor? Behind the generator? Are Therese different versionsof these? The car i took the engine out of just had a tid. Also the dipstick from the 99 engine is considerably shorter than the 95 dipstick? Seems original though. Oil level is at Max according to dipstick that came with new engine. It says oil lack constantly when i turn on the ignition. The check oil level Message i havent seen since the old engine was running. Also oil pressure light goes out correctly once the engine starts. Any insight in this would be Nice.
