Author Topic: oil leak  (Read 1061 times)
Jrh
  • Rochester, KENT
  • Drive it like you stole it ^_^
    • 2.0 OMEGA
oil leak
« on: 14 July 2012, 11:27:26 »
as above only noticed other day when stopped as saw smoke coming from bonnet, it drips on to me down pipes would this be the rocker cover gasket? cause can see oil on side of the cover windscreen end of engine and what ever is below that is covered in it so its well lubed lol
Re: oil leak
« Reply #1 on: 14 July 2012, 11:29:13 »
More than likely
Big_Al
Re: oil leak
« Reply #2 on: 14 July 2012, 12:08:21 »
+1  agreed  . .  almost certainly cam cover ..    Only use genuine GM  gaskets ,o rings & black sealant . 8nm torque is critical . . absolutley no more  ;)
See maintenance guide for how it's done .... follow to the letter & you won't go wrong  :y :y
Andy c at Bury St Edmunds Vauxhall  will give you a good deal on the parts. Look under Recommended suppliers on here to find his contact details   :y :y
« Last Edit: 14 July 2012, 12:10:20 by Essex Big Al »
Jrh
  • Rochester, KENT
    • 2.0 OMEGA
Re: oil leak
« Reply #3 on: 14 July 2012, 12:23:50 »
ok thanks alot :)
