Author Topic: dump valve  (Read 3296 times)
maskedpump
  • Weston-super-Mare
    • Vauxhall Omega 2.2 DTI
dump valve
« on: 21 July 2012, 14:33:05 »
Hey guys, was just wandering, and not to be given any harsh words, but I'm wanting to fit a dump valve to my 2.2 dti omega.
I know you get a nice 'pssshhh' sound when letting lose on the gas or changing gear if you remove the air box just before the air flow cencor. However I want something a tad better and better sounding.
Any advice is greatly appreciated
I'd rather DRIVE a Vauxhall than PUSH a Ford
martin42
Re: dump valve
« Reply #1 on: 21 July 2012, 14:36:26 »
There used to be a kit you could buy,and it was operated by a micro switch on the gas pedal,so when you lifted off it used to operate the dump valve,was approx £100 .
maskedpump
  • Weston-super-Mare
Re: dump valve
« Reply #2 on: 21 July 2012, 14:39:04 »
OK thanks, any idea what they're called or where to look?
martin42
Re: dump valve
« Reply #3 on: 21 July 2012, 14:42:20 »
Try eBay  :y
Re: dump valve
« Reply #4 on: 21 July 2012, 16:17:10 »
I just get my misses to make the Pshhhhh noise its so much cheaper ::)
tgm147
  • Wirral
    • '02 2.2 Omega CD
Re: dump valve
« Reply #5 on: 21 July 2012, 19:25:06 »
http://www.zen19051.zen.co.uk/prod01.htm
Heard good things about him too.
jonnyboyws6
  • grimsby
Re: dump valve
« Reply #6 on: 21 July 2012, 22:43:15 »
I will restrain from commenting about diesels as you ask!
I've got a Bailey on my Celica and it sounds great, so good in fact it almost makes up for the 4 cylinder exhaust note, so I reckon if you can find something that makes yours sound as good go for it
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: dump valve
« Reply #7 on: 21 July 2012, 23:09:51 »
why put one on, every one ive seen on these boy racer cars has trouble going up hills ??
Solar charger fitted.
If not Broke dont fix it..
Re: dump valve
« Reply #8 on: 22 July 2012, 09:02:55 »
Peg a playing card to the spokes...? ;)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: dump valve
« Reply #9 on: 22 July 2012, 10:12:11 »
Dump valves. Why? lol do they actually aid performance other than the ''ttsssshhh''?
RIP Paul Lovejoy
Re: dump valve
« Reply #10 on: 22 July 2012, 10:21:02 »
You need to have a throttle to have a dump valve, and diesels don't have a throttle. ;)
martin42
Re: dump valve
« Reply #11 on: 22 July 2012, 10:36:23 »
That's why its controlled electronically  :y
Re: dump valve
« Reply #12 on: 22 July 2012, 10:59:38 »
But why fit it at all? The point of a dump valve is to relieve excess boost when the throttle is closed suddenly and the turbo is still spinning at full chat. You don't have a throttle, so don't need to relieve the boost. On a diesel surely all it'll do is give you more lag when you get back on the power, as the turbo has to build pressure in all the intake pipework again?  :-\
.. if it's just for the noise, surely an electronic box that goes "pisssssh" connected to the microswitch would be a better idea?
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
Re: dump valve
« Reply #13 on: 22 July 2012, 11:23:50 »
You sure about that Pete?
You don't value Mrs Pete very highly!! ;D
best wishes
Simon.
Re: dump valve
« Reply #14 on: 22 July 2012, 21:40:50 »
I'm with Kevin Wood, I don't think it can be made to work on a diesel...
