Author Topic: God damn door pin  (Read 3070 times)
omegod
  • liverpool
    • 2017 Seat Ateca
God damn door pin
« on: 24 July 2012, 21:00:28 »
Can't get the frigging door pin out and just snapped the removal tool,  Im gonna cut the  b*stard door off with my whizzer >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:(
Stand by with the extinguisher wifey  :o ;D
Re: God damn door pin
« Reply #1 on: 24 July 2012, 21:01:40 »
No tool needed. A drift and a hammer.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 24 July 2012, 21:14:05 »
Tried a drift, no joy , even put a jack under it but the car just started going up. Heat and even terrible swearing wouldn't budge it either.
« Reply #3 on: 24 July 2012, 21:55:03 »
Not sure where you could be jacking the door pin if the car was being lifted ......  ??? ???
Both pins come out toward the middle ie the top pin goes down & the bottom pin goes up, I used this
and a big hammer. Try knocking each pin the wrong way to help release it before you use something to pull each pin out.
« Reply #4 on: 24 July 2012, 22:15:38 »
pair of mole grips on the pin,then tap the molegrips to drift the pin out - seemples. ;)
flyer 0712
« Reply #5 on: 24 July 2012, 22:55:11 »
Jack sealey do a hinge pin remover tool that comes complete with 3 different size pins and the removal tool for about £25 retail..part number vs801......i have had one for years and always done the trick with it. :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #6 on: 25 July 2012, 07:48:38 »
Thats the one that broke!   Done a few with it but it just sheared on this one.
Andy it's the lower pin that needs to go up, drift under pin, jack under drift as thought weight of car would pop it out, no joy. It's getting cut off today
the alarming man
  • medway kent
    • disco V8
« Reply #7 on: 25 July 2012, 07:58:37 »
on my sport i used TB method and worked ok.....unless yours had been mullered before..... :y
« Reply #8 on: 25 July 2012, 09:24:10 »
I'd say there'd be too much of an angle  :-\  :-\  :-\  :-\
If you have a small dremel type cutting disc, you could try cutting the top flare off & then drive the old pin out downwards. You might have a bit more room to swing your hammer between the hinges rather than below the lower hinge.  :-\
« Reply #9 on: 25 July 2012, 12:50:00 »
I'm with Albs and the Molegrips on this one. The hinge pin has a split down it so the Molegrips pinch the pin together
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #10 on: 26 July 2012, 07:06:36 »
best wishes
Simon.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #11 on: 26 July 2012, 07:54:17 »
Managed to get it off eventually with a heat/molegrip/drift/swearing combination!
Sealey removal tools are crap all round!
